Home » Newcomers » Newcomers » Starting eclipse failed
Starting eclipse failed [message #251114] Sun, 09 March 2008 13:57 Go to next message
Originally posted by: Norbert.Meyer.gmx.net
i'm a newcomer and have installed eclipse on Laptop Dell Inspiron 1100
under Windows XP Professional. When i start eclipse after the
installation, eclipse is not started and the following error occurs in the
logfile. I've tried severals java editions jre 5.0 etc, but nothings helps.
Thanks for help,
Norbert
!SESSION 2008-03-05 20:09:22.277
eclipse.buildId=M20080221-1800
java.version=1.6.0_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2008-03-05 20:09:23.239
!MESSAGE Bundle org.eclipse.update.configurator@3:start not found.
!ENTRY org.eclipse.core.runtime 4 0 2008-03-05 20:09:23.379
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.core.jobs;
bundle-version="[3.2.0,4.0.0)"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:305)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelMana
Re: Starting eclipse failed [message #251121 is a reply to message #251114] Sun, 09 March 2008 14:11 Go to previous messageGo to next message
Norbert,
Which version of Eclipse have you installed? How did you install it?
(Zip file or update manager? Which version/which site? Did you install
it in a new location, or over top of an old installation? Try clearing
the log and starting again with -clean -debug and see what kinds of
messages show up then...
Norbert wrote:
> Hello,
> the logfile. I've tried severals java editions jre 5.0 etc, but
> nothings helps.
> Thanks for help,
> Regards
> Norbert
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
Re: Starting eclipse failed [message #251294 is a reply to message #251121] Tue, 11 March 2008 15:54 Go to previous message
thank you for your help. It was the first installation of eclipse v3.3.2
by unpacking the zip-file "eclipse-cpp-europa-winter-win32.zip" from a
german eclipse server. The problem was solved after reinstalling the
eclipse dir and calling eclipse -clean -debug at first. It's seems that
the subdirectories in the directory "configuration" was not there. After
-clean the subdirectories were created and eclipse is starting now.
Norbert
Previous Topic:JFace TableViewer and Progress Bar/Indicator
Next Topic:create plug-in programmatically
Current Time: Thu Jul 24 21:14:24 EDT 2025
Powered by FUDForum. Page generated in 0.09611 seconds
