How do I add JEE JavaDocs? [message #250846] |
Wed, 05 March 2008 08:01  |
Originally posted by: Qu0llSixFour.gmail.com
I have added a GlassFish v2 runtime to my Eclipse 3.3.2 installation but how
do I specify the location of the JavaDocs? At the moment, when I reference
classes in javax.servlet for example, the docs cannot be found by code
completion. At least I am assuming that's the problem as no docs are
displayed for methods selected in code completion from such classes.
And loving it,
-Q
_________________________________________________
Qu0llSixFour@gmail.com
(Replace the "SixFour" with numbers to email me)
Re: How do I add JEE JavaDocs? [message #250895 is a reply to message #250882] |
Wed, 05 March 2008 13:49  |
"Mark Dexter" <dextercowley@gmail.com> wrote in message
news:fqmkej$sfv$1@build.eclipse.org...
>> how do I specify the location of the JavaDocs? At the moment, when I
>> reference classes in javax.servlet for example, the docs cannot be found
>> by code completion. At least I am assuming that's the problem as no docs
>> are displayed for methods selected in code completion from such classes.
> Hi. I'm assuming that you added the GlassFish runtime as an external jar
> file. If so, if you go to the Libraries tab on the Java Build Path (e.g.,
> Project/Properties/Java Build Path), drill down to find the GlassFish jar
> file and expand it, you will see a place to enter the JavaDocs, either has
> a URL or a local resource. Hope this helps. Mark
Thanks Mark, it works now.
And loving it,
-Q
FUDForum. Page generated in 0.09175 seconds
