Home » Newcomers » Newcomers » Which Eclipse package should I start with?
Which Eclipse package should I start with? [message #250474] Fri, 29 February 2008 09:22 Go to next message
Originally posted by: dsv250.bellsouth.net
I've been writing simple utility programs in VisualAge for Java for
several years and have decided it's time to step in to the future with
Eclipse. I know nothing about Eclipse and am trying to determine which
of the following packages I should download to get started. Can anyone
help me with this? I'll be writing java applications with GUI interfaces.
Eclipse IDE for Java Developers
Eclipse IDE for Java EE Developers
Eclipse IDE for C/C++ Developers
Eclipse for RCP/Plug-in Developers
Eclipse Classic 3.3.1.1
Re: Which Eclipse package should I start with? [message #250477 is a reply to message #250474] Fri, 29 February 2008 09:55 Go to previous messageGo to next message
I'd go for the first one, unless you expect to be developing Eclipse
applications (which seems likely if you want to build GUIs) and then I'd
pick the RCP/Plug-in one.
> which of the following packages I should download to get started. Can
> anyone help me with this? I'll be writing java applications with GUI
> interfaces.
Re: Which Eclipse package should I start with? [message #250495 is a reply to message #250477] Fri, 29 February 2008 10:50 Go to previous messageGo to next message
>> interfaces.
Thanks for your response. Are these choices mutually exclusive or can I
download the first one and then later download a second one for more
functionality?
Re: Which Eclipse package should I start with? [message #250496 is a reply to message #250495] Fri, 29 February 2008 10:55 Go to previous messageGo to next message
No matter which package you start with, you can use the update manager
and the Europa update site to install additional things later.
>> I'd pick the RCP/Plug-in one.
>>> with Eclipse. I know nothing about Eclipse and am trying to
>>> determine which of the following packages I should download to get
>>> started. Can anyone help me with this? I'll be writing java
> I download the first one and then later download a second one for
> more functionality?
Re: Which Eclipse package should I start with? [message #250515 is a reply to message #250495] Fri, 29 February 2008 11:05 Go to previous messageGo to next message
> functionality?
Everything in Eclipse is a plugin, so you can always add functionality
by installing more plugins. Those packages are just convenient bundles
that include commonly used plugins together. As Ed said, start with the
first one and then later you can use the Update Manager to install other
features from the Europa Discovery Site (you'll understand what that is
when you go to use the Update Manager via Help > Software Updates > Find
and Install).
On the Downloads page where those packages are listed, there are links
to find out more about each one and to compare what is in each package.
There is also a link (on the right side, IIRC) to an article explaining
how to use the Update Manager.
Hope this helps,
Eric
Re: Which Eclipse package should I start with? [message #250526 is a reply to message #250495] Fri, 29 February 2008 12:54 Go to previous message
> functionality?
Thanks for the great comments! I think I have what I need to get started.
Previous Topic:Does the xml plug-in (xmlbuddy) work in Eclipse 3.3 version?
Next Topic:spell check + StyledText
Current Time: Fri Jul 18 00:33:45 EDT 2025
Powered by FUDForum. Page generated in 0.12838 seconds
