Home » Newcomers » Newcomers » Discovering branch and version tags
Discovering branch and version tags [message #250422] Thu, 28 February 2008 20:04 Go to next message
Originally posted by: patricia_shan8.hotmail.com
The documentation for Eclipse at "Discovering branch and version tags" is
not clear.
What are the implications of:
(1) adding checked tabs to the list of remembered tags
(2) adding remembered tags to the selected repository location or project
What is the purpose of this?
Do they cause a change to the repository?
Are they used by people using the repository, and if so how?
Thank you
Re: Discovering branch and version tags [message #250508 is a reply to message #250422] Fri, 29 February 2008 11:00 Go to previous message
> is not clear.
No, those things only affect your local Eclipse configuration, not the
repository. In general, Eclipse will only change the repository when you
explicitly tell it to do so (via a Commit or adding a project to the
repository).
Those functions just store data about the tags locally so you don't have
to go through this process frequently.
Hope this helps,
Eric
Previous Topic:How to search this group
Next Topic:Does the xml plug-in (xmlbuddy) work in Eclipse 3.3 version?
Current Time: Fri Nov 21 09:46:24 EST 2025
Powered by FUDForum. Page generated in 0.30009 seconds
