Home » Eclipse Projects » DSDP - Target Management » Retrieving the sytem registry from within JUnit
Retrieving the sytem registry from within JUnit [message #24633] Thu, 03 July 2008 10:29 Go to next message
Originally posted by: paul.pwrutter.com
I'm trying to write some JUnit tests that need to have access to a remote
system in order to copy files across. I am trying access the registry via
RSECorePlugin.getTheSystemRegistry(), which works fine within a UI Thread
but simply returns NULL from within a JUnit Thread. Do you have any advice
on how to retrieve the system registry from within JUnit? I am currently
using:
Display.getDefault().syncExec(new Runnable() {
public void run() {
ISystemRegistry registry =
RSECorePlugin.getTheSystemRegistry();
But to no avail.
Many Thanks
Paul
Re: Retrieving the sytem registry from within JUnit [message #24754 is a reply to message #24633] Fri, 11 July 2008 10:01 Go to previous message
Hi Paul,
I think that at the time being, you'll need to run your unit
tests as "JUnit Plug-in test" which starts a complete Eclipse
instance. Then, ensure that the RSEUIPlugin is loaded.
For example, look at our unit tests in org.eclipse.rse.tests
-- The RSEFileServiceTest as well as the RSEFileStoreTest classes should
have some helpful code for you.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Paul Rutter wrote:
> Hi
> remote system in order to copy files across. I am trying access the
> registry via RSECorePlugin.getTheSystemRegistry(), which works fine
> within a UI Thread but simply returns NULL from within a JUnit Thread.
> Do you have any advice on how to retrieve the system registry from
> within JUnit? I am currently using:
> public void run() {
> RSECorePlugin.getTheSystemRegistry(); }
> But to no avail.
> Many Thanks
> Paul
Re: Retrieving the sytem registry from within JUnit [message #575912 is a reply to message #24633] Fri, 11 July 2008 10:01 Go to previous message
Hi Paul,
Paul Rutter wrote:
> Hi
> public void run() {
> But to no avail.
> Many Thanks
> Paul
Previous Topic:Need a simple tutorial or help
Next Topic:Custom port for SSH in Remote Systems
Current Time: Thu Nov 06 20:17:32 EST 2025
Powered by FUDForum. Page generated in 0.05060 seconds
