Home » Language IDEs » Java Development Tools (JDT) » Cryptic Build Error (No location given)
Cryptic Build Error (No location given) [message #250330] Thu, 20 December 2007 16:21 Go to next message
Originally posted by: hal.thresholddigital.com
I just upgraded my Ubuntu system to the latest version and had a bit of
trouble with Eclipse, so I removed it and reinstalled, using the Ubuntu
repository. It's running 3.2.2. One of my projects uses OpenOffice,
including all the jar files. Because of the upgrade, I did have to
respecify the location of all the OpenOffice jar files (I think the
developers blow off steam by changing the jars a bit at each release). I
did that and all but one error on that project went away.
This one error is:
The project cannot be built until build path errors are resolved
Yet I don't get anything specific. I've tried the Configure Build Path
window, and don't see any errors flagged and in the Package Explorer
there's no indication of errors. The location is given as unknown and if I
try "Goto Location" I don't get anything.
It seems to be just an inspecific error with no guidance on how to fix it.
How can I either fix it or at least get more information on it?
Thanks!
Hal
Re: Cryptic Build Error (No location given) [message #250334 is a reply to message #250330] Fri, 21 December 2007 09:23 Go to previous message
> This one error is:
The project's build path is configured via its Properties dialog. If you
open the Properties and select the Java Build Path section you should be
able to find the problem by switching between the various tabs (Source,
Projects, Libraries).
Hope this helps,
Eric
Previous Topic:MethodInvocation -- get calling Type?
Next Topic:annoying timestamp change in pref file
Current Time: Sat Jul 26 14:40:57 EDT 2025
Powered by FUDForum. Page generated in 0.03550 seconds
