| Covariant Return Types [message #250309] |
Mon, 07 June 2004 18:56  |
Originally posted by: robert.elliot.dial.pipex.com
Hi all. I've met an issue with Eclipse 3 M9 (and also as it happens
WSAD5) which isn't really a bug as such. Basically, I've written an API
using Java 1.5 syntax, including covariant return types. Having compiled
it up using a 1.5 javac, I ran an excellent little utility called
Retroweaver over it which transforms 1.5 byte code to make it 1.2, 1.3 and
1.4 compatible. Then jarred it up, and imported the jar into an Eclipse
Java project; but Eclipse doesn't like it. The API contains 2 classes
effectively doing the following:
// Initial class
public abstract class Foo {
protected Object foo() {
return "Hi";
// Subclass that over-rides foo() with a covariant return type
public abstract class FooExt extends Foo {
protected String foo() {
return (String) super.foo();
The intention of the API is that clients subclass FooExt to provide public
methods. So having brought the API jar into a Java 1.3 Eclipse project, I
created a new java file subclassing FooExt as follows:
public class Bar extends FooExt {
public String getText() {
return foo();
Now that will compile fine from the command line using a 1.3 javac with a
-classpath pointing at my bytecode modified API jar, and the result will
run fine on a 1.3 JVM. However, both Eclipse & WSAD really don't like it
because of the covariant return types; I get a red X by the first line of
the class and doing mouse over displays the following error message:
- The return type is incompatible with Foo.foo(), FooExt.foo()
So my query is, do the Eclipse team think this is something worth "fixing"
in Eclipse, since 1.3 compilers and JVMs are happy with it? Or do they
consider that this is a (useful!) bug in the 1.3 compilers and JVMs since
they are not meant to support covariant return types, and so not something
Eclipse should be worried about?
Rob
FUDForum. Page generated in 1.35800 seconds
