Home » Eclipse Projects » Eclipse Platform » Plugins not loaded
Plugins not loaded [message #250218] Mon, 07 June 2004 14:45 Go to next message
I am having a problem where my plugins are not showing up when I first
start up Eclipse 3.0 RC1. If I go to runtime Workbench the plugins do
show up there and work correctly. If I run Eclipse using the -console
option and type the ss command, my plugins are listed as installed. Also,
other people using the exact version of the plugin have it working fine on
M9 and RC1. I am using IBM's JDK 1.4.2 and am runnign Eclipse using the
-vm target pointing it at my 1.4.2 installation. Any help would be
greatly appreciated. Thank you very much.
Here is a copy of the four plugins manifest files:
Manifest-Version: 1.0
Generated-from: 1086632136000;type=2
Bundle-Name: %pluginName
Bundle-SymbolicName: com.ibm.sample.zip.creation; singleton=true
Bundle-Version: 1.0
Bundle-ClassPath: runtime.jar
Bundle-Activator: org.eclipse.core.internal.compatibility.PluginActivator
Bundle-Vendor: IBM
Bundle-Localization: plugin
Require-Bundle: org.eclipse.core.resources,
org.eclipse.ui,
org.eclipse.ui.ide;optional=true,
org.eclipse.ui.views;optional=true,
org.eclipse.ui.editors;optional=true,
org.eclipse.jface.text;optional=true,
org.eclipse.ui.workbench.texteditor;optional=true,
org.eclipse.jdt.core,
org.eclipse.core.runtime.compatibility,
org.eclipse.core.runtime;bundle-version="2.1"
Eclipse-AutoStart: true
Plugin-Class: com.ibm.sample.zip.creation.ZipPlugin
Bundle-SymbolicName: com.ibm.ws.build.plugin; singleton=true
Bundle-Version: 1.0.0
Bundle-ClassPath: wsbld_plugin.jar
Bundle-Vendor: IBM Corp. - WebSphere Server Group
Provide-Package: com.ibm.ws.build.plugin,
com.ibm.ws.build.plugin.dialogfields,
com.ibm.ws.build.plugin.wsant,
com.ibm.ws.build.plugin.create
Require-Bundle: com.ibm.ws.build.wsant;bundle-version="[5.0.0,6.0.0)",
org.eclipse.ui,
org.eclipse.swt,
org.eclipse.debug.core,
org.eclipse.debug.ui,
org.eclipse.jdt.launching,
org.eclipse.ui.externaltools,
Plugin-Class: com.ibm.ws.build.plugin.EclipseToolsPlugin
Bundle-SymbolicName: com.ibm.ws.build.wsant; singleton=true
Bundle-Version: 5.0.0
Bundle-ClassPath: ant.jar,
jakarta-ant-1.4.1-optional.jar,
jakarata-regexp-1.2.jar,
jdepend.jar,
NetComponents.jar,
tools.jar,
wasproduct.jar,
xalan.jar,
xsdbeans.jar
Bundle-Vendor: %providerName
Provide-Package: com.sun.tools.jdi,
com.ibm.som.idlemit,
org.apache.tools.ant.taskdefs.cvslib,
com.ibm,
com.sun.tools.javadoc,
sun.tools.serialver,
org.apache.xpath.patterns,
com.ibm.som.cff,
sun.tools.native2ascii.resources,
org.apache.tools.zip,
org.apache.tools.ant.util,
com.sun.tools.javac.v8.tree,
org.apache.xpath.res,
org.apache.tools.ant.helper,
jdepend.framework,
com.ibm.idl.constExpr,
com.sun.tools.javah.resources,
com.ibm.websphere.product.xml,
com.oroinc.net.pop3,
org.apache.xml.dtm,
com.oroinc.net,
org.apache.tools.ant.filters.util,
com.ibm.ws.build.streamutil,
com.oroinc.net.telnet,
sun.tools.crunch,
com.sun.tools.doclets.standard.resources,
sun.tools.javazic,
com.oroinc.net.bsd,
com.ibm.ws.launcher.server,
org.apache.xalan.xslt,
org.apache.tools.ant,
org.apache.xpath.axes,
jdepend.xmlui,
org.apache.xml.utils,
com.sun.tools.javac.v8.resources,
com.ibm.websphere.product.xml.websphere,
com.sun.tools.example.debug.tty,
com.sun.tools.jdi.resources,
org.apache.xalan.serialize,
com.ibm.ws.launcher.server.actions,
org.apache.xalan.res,
org.apache.xpath.operations,
com.oroinc.io,
org.apache.xalan.extensions,
com.ibm.ws.build.tools,
com.sun.tools.doclets.standard,
com.ibm.ejavadoc,
org.apache.tools.ant.taskdefs,
org.apache.tools.ant.types,
com.sun.tools.doclets.resources,
org.apache.xml.utils.res,
com.ibm.ws.build.tasks,
com.ibm.ejavadoc.analyses,
org.apache.tools.bzip2,
com.ibm.ws.launcher.server.editors,
jdepend.textui,
com.sun.jdi.connect,
org.apache.tools.ant.taskdefs.compilers,
com.sun.tools.doclets,
com.ibm.websphere.product,
org.apache.xalan.templates,
com.ibm.ws.build.tasks.reports,
com.ibm.ws.build.loggers,
com.sun.javadoc,
com.ibm.websphere.product.formatters,
com.ibm.websphere.product.xml.component,
com.ibm.websphere.product.filters,
sun.tools.java,
com.oroinc.net.smtp,
com.sun.jdi.request,
com.oroinc.net.ftp,
org.apache.xpath.compiler,
jdepend.swingui,
com.sun.tools.doclets.standard.tags,
com.ibm.ws.build.model,
com.ibm.websphere.product.xml.product,
sun.tools.javap.oldjavap,
com.ibm.idl.toJavaPortable,
com.sun.tools.javac.v8,
sun.tools.util,
sun.tools.javap,
org.apache.tools.ant.taskdefs.rmic,
org.apache.xpath.functions,
org.apache.xml.dtm.ref,
com.ibm.tools.rmic.iiop,
org.apache.xalan.transformer,
sun.tools.javac.resources,
com.oroinc.util,
org.apache.tools.ant.filters,
sun.tools.native2ascii,
sun.tools.tree,
org.apache.tools.ant.types.selectors,
com.ibm.ws.build.tasks.javadoc,
com.sun.tools.javadoc.resources,
sun.rmi.rmic.resources,
org.apache.xalan.processor,
org.apache.xpath,
org.apache.tools.tar,
com.ibm.ws.build.tasks.mofutils,
org.apache.xalan,
images,
com.sun.tools.javac.v8.parser,
com.ibm.websphere.product.xml.efix,
com.sun.tools.javah,
com.ibm.ws.build.tasks.messages,
org.apache.tools.ant.taskdefs.email,
com.sun.jdi.event,
org.apache.xalan.client,
org.apache.xml.dtm.ref.dom2dtm,
com.ibm.ws.analyzers.dependency.common,
com.sun.tools.javac,
com.sun.tools.javac.v8.code,
com.sun.tools.javac.v8.util,
org.apache.tools.mail,
org.apache.tools.ant.util.facade,
org.apache.tools.ant.taskdefs.condition,
com.ibm.ws.build.utils,
com.sun.jdi,
com.sun.tools.javac.v8.comp,
org.apache.tools.ant.util.regexp,
com.ibm.etools.xmlschema.beans,
sun.tools.serialver.resources,
org.apache.xpath.objects,
com.sun.tools.extcheck,
org.apache.xalan.lib,
org.apache.xalan.trace,
sun.rmi.rmic,
com.ibm.ws.build.tasks.jar,
org.apache.xml.dtm.ref.sax2dtm,
org.apache.xalan.lib.sql,
sun.tools.asm,
com.sun.tools.example.debug.expr,
com.sun.tools.javah.oldjavah,
org.apache.tools.ant.input,
com.oroinc.net.nntp,
org.apache.tools.ant.listener,
com.oroinc.net.tftp,
com.ibm.ws.build.tasks.swsutils,
com.ibm.idl,
sun.tools.javac,
com.ibm.websphere.product.xml.extension,
Require-Bundle: org.eclipse.core.runtime;bundle-version="2.1",
Bundle-Name: IBM WebSphere Application Server Development Debug Launcher
Bundle-SymbolicName: com.ibm.ws.launcher.server; singleton=true
Bundle-ClassPath: wsdebuglaunch.jar
Provide-Package: com.ibm.ws.launcher.server,
Require-Bundle: org.eclipse.ui,
org.eclipse.swt,
Plugin-Class: com.ibm.ws.launcher.server.WebSphereLauncherPlugin
Re: Plugins not loaded [message #250390 is a reply to message #250218] Tue, 08 June 2004 05:56 Go to previous messageGo to next message
Originally posted by: thomas_maeder.ch.ibm.com
I don't know what's wrong, but it might help if you defined what "the
plugins don't show up" means. Are your views not shown when you try to
open them?
I run on an IBM JDK, too and I don't have any trouble (not the exact
same one, though).
Thomas
<snip>
Re: Plugins not loaded [message #250538 is a reply to message #250390] Tue, 08 June 2004 11:13 Go to previous messageGo to next message
I mean that my plugins extend the import wizard or add a menu under the
main bar (add a menu with File, Edit, etc.) and they are not showing up as
options under the import wizard or on the main menu bar. HOwever, if I go
into runtime workbench, they appear and work fine.
> open them?
> same one, though).
> Thomas
> <snip>
Re: Plugins not loaded [message #250542 is a reply to message #250538] Tue, 08 June 2004 11:30 Go to previous messageGo to next message
>>open them?
>>same one, though).
>>Thomas
>><snip>
Did you install them in your plugins directory? I may be wrong but it
sounds like you are expecting the plugins that you are creating to just
show up in eclipse when you restart. If that is the case you need to
export the plugins and install them into your plugins dir. They show up
in the runtime workbench because its there to test and debug your
plugins while creating them, so your plungin projects get added to the
rtwb when it starts.
Rob..
Re: Plugins not loaded [message #250546 is a reply to message #250542] Tue, 08 June 2004 11:30 Go to previous messageGo to next message
These plugins are not actually set up as a plugin project, they are part
of another Java project and they are built using ant which generates a zip
file which can then be unzipped directly into my plugins folder. I unzip
them there and running in runtime workbench adds nothing because the code
for the plugins is not even brought in as a project.
> >>open them?
> >>same one, though).
> >>Thomas
> >><snip>
> Rob..
Re: Plugins not loaded [message #250550 is a reply to message #250546] Tue, 08 June 2004 11:53 Go to previous messageGo to next message
>>>>open them?
>>>>same one, though).
>>>>Thomas
>>>><snip>
>>Rob..
Do the plugins show up in the plugin-details under Help >> About
Eclipse? Also, Is there anything in the log file that shows them
not loading correctly?
R
Re: Plugins not loaded [message #250562 is a reply to message #250550] Tue, 08 June 2004 12:02 Go to previous message
There is nothing in the log file and the plugin do appear in the
plugin-details section.
> R
Previous Topic:Difficult time finding plug-in properties
Next Topic:Appending a newline to a Document
Current Time: Tue Nov 04 21:24:40 EST 2025
Powered by FUDForum. Page generated in 0.04842 seconds
