Home » Eclipse Projects » Eclipse Platform » MESSAGE Unable to access "http://update.eclipse.org/updates/3.0".
MESSAGE Unable to access "http://update.eclipse.org/updates/3.0". [message #250133] Mon, 07 June 2004 11:20 Go to next message
Hello All,
Sorry but I am new to Eclipse. Did I miss something that updates for 3.0 are
unavaible using the Eclipse IDE or something to that affect? Can't seem to
use the check for updates IDE option:
Menu /Help/Software Updates/Find and Install
I have a log export for this particular error.
Thanks in Advance..
Bill
!SESSION Jun 05, 2004
13:49:57.749 ---------------------------------------------
eclipse.buildId=I200405260010
java.version=1.5.0-beta
!ENTRY org.eclipse.update.core 4 42 Jun 05, 2004 13:49:57.749
!MESSAGE Unable to access "http://update.eclipse.org/updates/3.0".
!SUBENTRY 1 org.eclipse.update.core 4 42 Jun 05, 2004 13:49:57.749
!MESSAGE Unable to access Site stream:
[http://update.eclipse.org/updates/3.0]
!STACK 0
java.io.FileNotFoundException: http://update.eclipse.org/updates/3.0
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(U nknown
Source)
org.eclipse.update.internal.core.ConnectionThreadManager$Str eamRunnable.run(
ConnectionThreadManager.java:75)
at java.lang.Thread.run(Unknown Source)
Re: MESSAGE Unable to access "http://update.eclipse.org/updates/3.0". [message #250165 is a reply to message #250133] Mon, 07 June 2004 12:01 Go to previous message
Originally posted by: ilias.lazaridis.com
WEConsultants wrote:
> Hello All,
> Thanks in Advance..
> Bill
Things around update are not clear:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=63618
[You may ask for increasing priority of this bug]
could be critical.
[you should prefere eclipse 2.1.3 for production]
coulde be critical.
http://www.lazaridis.com
Previous Topic:how a selection event broadcast?
Next Topic:Deprecated AbstractUIPlugin (IPluginDescriptor descr) called from Eclipse M9?
Current Time: Sat Nov 22 06:38:55 EST 2025
Powered by FUDForum. Page generated in 0.07743 seconds
