Home » Eclipse Projects » Nebula » Runtime compatibility
Runtime compatibility [message #2102] Thu, 18 May 2006 10:24 Go to next message
Hi.
I have downloaded the new grid control and it works very well, so far.
However I see that it was compiled using the java 5.0 features and it
isn't compatible with an 1.4 runtime. Is this going to be a requirement
for using the Nebula controls ?
Bye
Re: Runtime compatibility [message #3121 is a reply to message #2102] Thu, 18 May 2006 11:25 Go to previous messageGo to next message
Hi Marco,
No. The Grid widget is being refactored and all 5.0 features will be
removed. I believe the API is clear of lists and generics already.
Generally Nebula widgets should attempt to be CLDC compliant like SWT
(iow, a subset of 1.3 features).
-Chris
Marco Maccaferri wrote:
> Hi.
> Bye
Re: Runtime compatibility [message #3155 is a reply to message #3121] Fri, 19 May 2006 11:29 Go to previous messageGo to next message
That's great! Do you have an estimated timeframe for the new build ?
This control is the solution to so many requirements that I can't wait
using it.
Bye
Re: Runtime compatibility [message #3189 is a reply to message #3155] Fri, 19 May 2006 15:38 Go to previous message
No I don't sorry. You can always submit patches with the updated code.
I've filed a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142840
-Chris
> using it.
> Bye
Re: Runtime compatibility [message #561571 is a reply to message #2102] Thu, 18 May 2006 11:25 Go to previous message
Hi Marco,
-Chris
> Hi.
> Bye
Re: Runtime compatibility [message #561590 is a reply to message #3121] Fri, 19 May 2006 11:29 Go to previous message
using it.
Bye
Re: Runtime compatibility [message #561612 is a reply to message #3155] Fri, 19 May 2006 15:38 Go to previous message
-Chris
> using it.
> Bye
Previous Topic:Runtime compatibility
Next Topic:Presentation?
Current Time: Sat Jul 26 20:50:14 EDT 2025
Powered by FUDForum. Page generated in 0.03756 seconds
