| Re: Exception Handling in Birt [message #251268 is a reply to message #250053] |
Sun, 05 August 2007 09:35  |
Originally posted by: sjaheer.gmail.com
hi scott,
i want to handle the exceptions and to print the custom message for the
user
for example am connecting to database by using a jndi name and i want to
check before running or executing the report for connection is available
or not if connection is not available or connection is inactive then i
want to display a custom message to the user
As of now if database is down or any of the parameters not set properly
then while running the report it wont show any exceptions it will keep try
or after some time it wil display as empty.
so to avoid this i want to handle the exceptions,
thanks
FUDForum. Page generated in 0.04906 seconds
