Home » Archived » BIRT » HELP!! BIRT Servlet cannot run more than once
HELP!! BIRT Servlet cannot run more than once [message #249895] Wed, 25 July 2007 21:37 Go to next message
Originally posted by: jeremydorall.yahoo.com
Hello guys,
I'm a bit in a fix right now. I've compiled the following code in my
windows xp pc. Basically, what this code does is that it generates a new
rptdesign file based on the parameters received from the user. Now here's
the weird part. If i run the following servlet for the first time, it will
work, but if i were to run it again, then it wont. It seems as though the
previous session has been locked.What could be the problem? Could someone
please help me out with this??
Thanks a lot!!
Here's the code :
import java.io.*;
import java.util.*;
import java.util.Date;
import java.text.*;
import java.sql.*;
import javax.servlet.*;
import javax.servlet.http.*;
import java.io.IOException;
import java.io.PrintWriter;
import java.util.ArrayList;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.model.api.CellHandle;
import org.eclipse.birt.report.model.api.DataItemHandle;
import org.eclipse.birt.report.model.api.DesignConfig;
import org.eclipse.birt.report.model.api.ElementFactory;
import org.eclipse.birt.report.model.api.IDesignEngine;
import org.eclipse.birt.report.model.api.IDesignEngineFactory;
import org.eclipse.birt.report.model.api.LabelHandle;
import org.eclipse.birt.report.model.api.OdaDataSetHandle;
import org.eclipse.birt.report.model.api.OdaDataSourceHandle;
import org.eclipse.birt.report.model.api.PropertyHandle;
import org.eclipse.birt.report.model.api.ReportDesignHandle;
import org.eclipse.birt.report.model.api.RowHandle;
import org.eclipse.birt.report.model.api.SessionHandle;
import org.eclipse.birt.report.model.api.StructureFactory;
import org.eclipse.birt.report.model.api.TableHandle;
import org.eclipse.birt.report.model.api.activity.SemanticException ;
import
org.eclipse.birt.report.model.api.elements.structures.Comput edColumn;
import com.ibm.icu.util.ULocale;
public class testservlet extends HttpServlet
private static final long serialVersionUID = 1L;
ReportDesignHandle designHandle = null;
ElementFactory designFactory = null;
StructureFactory structFactory = null;
public ArrayList al = new ArrayList();
public Date date = new Date();
public SimpleDateFormat simpledate = null;
protected void doGet(HttpServletRequest
request,HttpServletResponse response)
throws ServletException,IOException
int i;
String queryString;
String strTable;
PrintWriter out = response.getWriter();
try
//Code to go through the parameters sent over
queryString = request.getParameter("txtSelect");
strTable = request.getParameter("txtFrom");
strTable = "From " + strTable;
//out.println(fieldarray.length);
//Parse the query sent over and place it in an
array
out.println(queryString);
parseQuery(queryString);
buildReport(al, strTable );
catch ( IOException e )
// TODO Auto-generated catch block
e.printStackTrace();
catch ( SemanticException e )
void parseQuery(String queryString)
String[] strArray = null;
strArray = new String[100];
char c;
String str2 = "";
int x=0;
for(int i=0;i<queryString.length();i++)
c =queryString.charAt(i);
if (i == queryString.length() - 1)
str2=str2 + c;
strArray[x] = str2;
else
if (c == ',')
strArray[x] = str2;
//System.out.println(str2);
str2="";
x++;
else
str2 = str2 + c;
for(int y=0;y < strArray.length ;y++)
if(strArray[y]==null)
break;
else
//System.out.println(strArray[y]);
al.add(strArray[y]);
void buildDataSource( ) throws SemanticException
OdaDataSourceHandle dsHandle =
designFactory.newOdaDataSource(
"Data Source",
"org.eclipse.birt.report.data.oda.jdbc" );
dsHandle.setProperty( "odaDriverClass",
"com.mysql.jdbc.Driver" );
dsHandle.setProperty( "odaURL",
"jdbc:mysql://localhost/test" );
dsHandle.setProperty( "odaUser", "root" );
dsHandle.setProperty( "odaPassword", "*****" );
designHandle.getDataSources( ).add( dsHandle );
void buildDataSet(ArrayList cols, String fromClause ) throws
SemanticException
//This is where the query will be built
OdaDataSetHandle dsHandle = designFactory.newOdaDataSet(
"ds",
"org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet" );
dsHandle.setDataSource( "Data Source" );
String qry = "Select ";
for( int i=0; i < cols.size(); i++){
qry += " " + cols.get(i);
if( i != (cols.size() -1) ){
qry += ",";
qry += " " + fromClause;
dsHandle.setQueryText( qry );
designHandle.getDataSets( ).add( dsHandle );
void buildReport(ArrayList cols, String fromClause ) throws
IOException, SemanticException
//Configure the Engine and start the Platform
DesignConfig config = new DesignConfig( );
//Need to change the property here
//For Linux
config.setProperty("BIRT_HOME",
"/home/jcd/BIRT/birt-runtime-2_1_2/ReportEngine/");
//For Windows
//config.setProperty("BIRT_HOME", "C:/Documents and
Settings/jcd/My Documents/Jeremy_backup on Cljcd on pc
(Clhcw)/ALM/BIRT/birt-runtime-2_1_2/ReportEngine");
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory =
(IDesignEngineFactory) Platform
.createFactoryObject(
IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle(
ULocale.ENGLISH ) ;
try{
//open a design or a template
//For Linux //
//designHandle =
session.openDesign("/opt/tomcat/webapps/ALM/new_report_1.rptdesign ");
designHandle = session.createDesign();
//For Windows
//designHandle = session.openDesign("C:/Program
Files/Apache Software Foundation/Tomcat
6.0/webapps/testjsp/new_report_1.rptdesign");
designFactory = designHandle.getElementFactory( );
buildDataSource();
buildDataSet(cols, fromClause);
TableHandle table = designFactory.newTableItem(
"table", cols.size() );
table.setWidth( "100%" );
table.setDataSet( designHandle.findDataSet( "ds" ) );
PropertyHandle computedSet = table.getColumnBindings( );
ComputedColumn cs1 = null;
cs1 =
StructureFactory.createComputedColumn();
cs1.setName((String)cols.get(i));
cs1.setExpression("dataSetRow[\"" +
(String)cols.get(i) + "\"]");
computedSet.addItem(cs1);
// table header
RowHandle tableheader = (RowHandle)
table.getHeader( ).get( 0 );
LabelHandle label1 = designFactory.newLabel( (String)cols.get(i) );
label1.setText((String)cols.get(i));
CellHandle cell = (CellHandle) tableheader.getCells( ).get( i );
cell.getContent( ).add( label1 );
// table detail
RowHandle tabledetail = (RowHandle) table.getDetail( ).get( 0 );
tabledetail.getCells( ).get( i );
DataItemHandle data = designFactory.newDataItem(
"data_"+(String)cols.get(i) );
data.setResultSetColumn( (String)cols.get(i));
cell.getContent( ).add( data );
designHandle.getBody( ).add( table );
// Save the design and close it.
//First, make the filename unique by naming it by the datetime
simpledate = new SimpleDateFormat("yyyyMMddkkmmss");
//For Linux
designHandle.saveAs( "/opt/tomcat/webapps/WebViewerExample/" +
simpledate.format(date) + ".rptdesign" ); //$NON-NLS-1$
//For Windows
//designHandle.saveAs( "C:/Program Files/Apache Software
Foundation/Tomcat 6.0/webapps/birt-viewer/report.rptdesign" );
//$NON-NLS-1$
designHandle.close( );
}catch (Exception e){
Re: HELP!! BIRT Servlet cannot run more than once [message #250003 is a reply to message #249895] Thu, 26 July 2007 08:18 Go to previous messageGo to next message
Jeremy,
You have called Platform.startup(), but you haven't called
Platform.shutdown()
Snjeza
Jeremy wrote:
> Hello guys,
> here's the weird part. If i run the following servlet for the first
> time, it will work, but if i were to run it again, then it wont. It
> seems as though the previous session has been locked.What could be the
> problem? Could someone please help me out with this?? Thanks a lot!!
> Here's the code :
> import java.io.*; import java.util.*; import java.util.Date; import
> java.text.*; import java.sql.*; import javax.servlet.*; import
> javax.servlet.http.*; import java.io.IOException; import
> import org.eclipse.birt.core.framework.Platform; import
> org.eclipse.birt.report.engine.api.IReportEngine; import
> org.eclipse.birt.report.model.api.CellHandle; import
> org.eclipse.birt.report.model.api.DataItemHandle; import
> org.eclipse.birt.report.model.api.DesignConfig; import
> org.eclipse.birt.report.model.api.ElementFactory; import
> org.eclipse.birt.report.model.api.IDesignEngine; import
> org.eclipse.birt.report.model.api.IDesignEngineFactory; import
> org.eclipse.birt.report.model.api.LabelHandle; import
> org.eclipse.birt.report.model.api.OdaDataSetHandle; import
> org.eclipse.birt.report.model.api.OdaDataSourceHandle; import
> org.eclipse.birt.report.model.api.PropertyHandle; import
> org.eclipse.birt.report.model.api.ReportDesignHandle; import
> org.eclipse.birt.report.model.api.RowHandle; import
> org.eclipse.birt.report.model.api.SessionHandle; import
> org.eclipse.birt.report.model.api.StructureFactory; import
> org.eclipse.birt.report.model.api.TableHandle; import
> org.eclipse.birt.report.model.api.activity.SemanticException ; import
> public class testservlet extends HttpServlet { /**
> * */ private static final long serialVersionUID = 1L;
> ReportDesignHandle designHandle = null; ElementFactory
> designFactory = null; StructureFactory structFactory = null;
> public ArrayList al = new ArrayList(); public Date date =
> new Date(); public SimpleDateFormat simpledate = null;
> request,HttpServletResponse response) throws
> ServletException,IOException { int i;
> String queryString; String strTable;
> try {
> //Parse the query sent over and place it in an array
> buildReport(al, strTable ); }
> catch ( IOException e ) {
> e.printStackTrace(); }
> catch ( SemanticException e ) {
> } void parseQuery(String
> queryString) { String[] strArray = null; strArray = new
> String[100]; char c; String str2 = "";
> int x=0;
> for(int i=0;i<queryString.length();i++) {
> { str2=str2 + c;
> strArray[x] = str2;
> else {
> if (c == ',') {
> strArray[x] = str2;
> str2="";
> x++; }
> else {
> str2 = str2 + c;
> { if(strArray[y]==null)
> { break;
> } else
> } void buildDataSource( ) throws
> SemanticException {
> designFactory.newOdaDataSource( "Data
> Source", "org.eclipse.birt.report.data.oda.jdbc" );
> "com.mysql.jdbc.Driver" ); dsHandle.setProperty(
> "odaURL", "jdbc:mysql://localhost/test" );
> SemanticException {
> "ds",
> String qry = "Select "; for( int i=0; i < cols.size();
> i++){ qry += " " + cols.get(i);
> qry += ","; }
> } qry += " " +
> fromClause; dsHandle.setQueryText( qry );
> } void buildReport(ArrayList cols, String
> fromClause ) throws IOException, SemanticException {
> start the Platform DesignConfig config = new
> DesignConfig( );
> //Need to change the property here //For
> Linux config.setProperty("BIRT_HOME",
> //For Windows
> //config.setProperty("BIRT_HOME", "C:/Documents and Settings/jcd/My
> (Clhcw)/ALM/BIRT/birt-runtime-2_1_2/ReportEngine"); IDesignEngine
> engine = null; try{
> }catch( Exception ex){ ex.printStackTrace();
> ULocale.ENGLISH ) ;
> try{ //open a design or a template
> //For Linux //
> //designHandle =
> //For Windows
> //designHandle = session.openDesign("C:/Program Files/Apache Software
> Foundation/Tomcat 6.0/webapps/testjsp/new_report_1.rptdesign");
> buildDataSource(); buildDataSet(cols,
> fromClause);
> "table", cols.size() ); table.setWidth( "100%" );
> cs1 =
> cs1.setExpression("dataSetRow[\"" + (String)cols.get(i) + "\"]");
> // table header RowHandle
> tableheader = (RowHandle) table.getHeader( ).get( 0 );
> for( int i=0; i < cols.size(); i++){ LabelHandle label1 =
> label1.setText((String)cols.get(i)); CellHandle cell = (CellHandle)
> tableheader.getCells( ).get( i ); cell.getContent( ).add( label1 );
> // table detail RowHandle tabledetail = (RowHandle) table.getDetail(
> ).get( 0 ); for( int i=0; i < cols.size(); i++){
> tabledetail.getCells( ).get( i ); DataItemHandle data =
> designFactory.newDataItem( "data_"+(String)cols.get(i) );
> data.setResultSetColumn( (String)cols.get(i)); cell.getContent(
> ).add( data ); }
> //For Linux
> //For Windows //designHandle.saveAs(
> "C:/Program Files/Apache Software Foundation/Tomcat
> 6.0/webapps/birt-viewer/report.rptdesign" ); //$NON-NLS-1$
Re: HELP!! BIRT Servlet cannot run more than once [message #250293 is a reply to message #250003] Sun, 29 July 2007 23:16 Go to previous message
Snjeza
I've added the Platform.shutdown() command at the end of my code, but
unfortunately, it still doenst work. Im at wits end trying to solve this
issue.
Arghhh!!
Anyway, thanks for your suggestion Snjeza. Really appreatiate it
Jeremy
Snjezana Peco wrote:
> Jeremy,
> Platform.shutdown()
> Snjeza
> Jeremy wrote:
>> Hello guys,
>> Here's the code :
>> try {
>> int x=0;
>> { str2=str2 + c;
>> strArray[x] = str2;
>> else {
>> if (c == ',') {
>> strArray[x] = str2;
>> str2="";
>> x++; }
>> else {
>> str2 = str2 + c;
>> { break;
>> } else
>> SemanticException {
>> SemanticException {
>> "ds",
>> qry += ","; }
>> } qry += " " +
>> DesignConfig( );
>> //For Windows
>> engine = null; try{
>> ULocale.ENGLISH ) ;
>> //For Linux //
>> //designHandle =
>> //For Windows
>> fromClause);
>> cs1 =
>> cs1.setExpression("dataSetRow["" + (String)cols.get(i) + ""]");
>> ).add( data ); }
>> //For Linux
Previous Topic:problem when exporting to XLS
Next Topic:BIRT 2.2 Recommendations on JVM tuning parameters for Webapps embedding the reporting engine
Current Time: Tue Nov 18 12:47:38 EST 2025
Powered by FUDForum. Page generated in 0.02792 seconds
