Runtime compatibility [message #2102] |
Thu, 18 May 2006 10:24  |
Hi.
I have downloaded the new grid control and it works very well, so far.
However I see that it was compiled using the java 5.0 features and it
isn't compatible with an 1.4 runtime. Is this going to be a requirement
for using the Nebula controls ?
Bye
Re: Runtime compatibility [message #3189 is a reply to message #3155] |
Fri, 19 May 2006 15:38  |
No I don't sorry. You can always submit patches with the updated code.
I've filed a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=142840
-Chris
Marco Maccaferri wrote:
> On 18/05/2006 17:25 Chris Gross wrote:
>> No. The Grid widget is being refactored and all 5.0 features will be
>> removed. I believe the API is clear of lists and generics already.
>> Generally Nebula widgets should attempt to be CLDC compliant like SWT
>> (iow, a subset of 1.3 features).
> That's great! Do you have an estimated timeframe for the new build ?
> This control is the solution to so many requirements that I can't wait
> using it.
> Bye
Re: Runtime compatibility [message #561571 is a reply to message #2102] |
Thu, 18 May 2006 11:25  |
Hi Marco,
-Chris
> Hi.
> Bye
Re: Runtime compatibility [message #561590 is a reply to message #3121] |
Fri, 19 May 2006 11:29  |
using it.
Bye
Re: Runtime compatibility [message #561612 is a reply to message #3155] |
-Chris
> using it.
> Bye
FUDForum. Page generated in 0.48768 seconds
