| The time of Eclipse loading [message #249785] |
Fri, 04 June 2004 17:44  |
I was wondering why there so big difference in time of Eclipse loading
the first time after computer re-booting and next loadings? For instance
I tested it for medium size workspace:
Eclipse 2.1.2:
1-st load - 40c
2-nd load - 20c
Eclipse 3.0RC1:
1-st load - 75c
2-nd load - 35c
I performed tests on W2K machine with 512Mb memory, -Xmx400m.
Why so big difference and is there any way to improve the first load case?
Thanks.
| Re: The time of Eclipse loading [message #250602 is a reply to message #250507] |
Tue, 08 June 2004 13:52   |
You are right. In my case the cause of slow startup is the number of
opened files. It let me to assume that in my customer case the cause is
not in Eclipse kernel, but in background CDT activity (maybe, parsing or
indexing).
Below is a brief description about customer's configuration (Win XP).
"There are a lot of projects (this is C++) in the workspace. There are
only 2 or 3 files open. After a reboot, it takes about 20-30 seconds
for the splashscreen to come up. Then about another 30 seconds for the
IDE to make its presence known. After Eclipse has started up at least
once, it will only take about 30 seconds to start up."
Still not clear why there is such a big difference between 1-st and 2-nd
start-up. The same effect I observe in my Java case as well (Win 2000).
Thomas Mäder wrote:
> I can start eclipse with a reasonably large workspace in about 10-15
> secs (2.6 GHz Pentium 4, -Xmx 256M). Things to try would be:
> 1) make sure neither eclipse nor the workspace are loaded from a network
> drive
> 2) use a slightly smaller -Xmx value (you might be taking away too much
> memory from the system). I've never needed more than 256M.
> 3) How fast does an empty workspace come up? What's different (do you
> have many perspectives open, many editors, etc)?
> Close various perspectives/editors/whatevers to find out who's
> responsible. If you find a culprit, file a bug report.
> It would be interesting to know how your workspace is set up. How many
> classes, how big are the files, how is the classpath set up, etc.
> Thomas
>> instance I tested it for medium size workspace:
>> Eclipse 2.1.2:
>> 1-st load - 40c
>> 2-nd load - 20c
>> Eclipse 3.0RC1:
>> 1-st load - 75c
>> 2-nd load - 35c
>> case?
>> Thanks.
| Re: The time of Eclipse loading [message #250924 is a reply to message #250657] |
Wed, 09 June 2004 09:36  |
Thanks a lot, Ed! I didn't have a chance to read this articles. Hope
they together with your advices will be helpful.
Alex
Ed Burnette wrote:
> You can try the -vmargs -Xms128m option ('s' means minimum startup size);
> this will reduce some heap growing when you start up. Also I'll bet that
> 400m is too big, try playing around with that number to find an optimal one
> for this application, for example, -Xmx256m. JDK 1.5 is supposed to make
> this more automatic but we'll see.
> Also, I recommend you look at Dan Kehn's articles on tuning Eclipse's
> startup performance if you haven't already:
> http://www-106.ibm.com/developerworks/opensource/library/os- ecspy1/
> http://www-106.ibm.com/developerworks/opensource/library/os- ecspy2/
> Report any CDT performance issues over on their newsgroup or in bugzilla,
> and let us know what you find out so we can learn from your experiences.
FUDForum. Page generated in 0.05938 seconds
