Home » Eclipse Projects » Eclipse Platform » Customized, Eclipse based IDE - How to start?
Customized, Eclipse based IDE - How to start? [message #249760] Fri, 04 June 2004 16:54 Go to next message
Originally posted by: rajan11.hotmail.com
Hi All,
I am working on a project where by, I need to develope an IDE for a simple
language that I am developing. I know that I can do that in Eclipse but
what I don't know is "where to start". Here is what I want to do:
1. User should be able to create projects and add one or mode source files.
2. Source is developed using customized language, hence need a complete
editor.
3. I also need CVS support, so that the user will have versioning
capablity.
4. Customized menu/toolbar so that the user gets to see only required
actions.
5. I have a parser that generates java code from the specified source code,
hence I would also like a debugging support (but at the custom language
level (desired, but not required immediately)
6. How to package this so that I have the smalled footprint/package size.
Any help will be greatly appreciated to get me started.
BTW, Eclipse rocks.
-RD
Re: Customized, Eclipse based IDE - How to start? [message #249837 is a reply to message #249760] Fri, 04 June 2004 21:06 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
I suggest starting with the editor. The plug-in examples package available
from the download page has a simple Java editor example, and there's a
sample XML editor in the new plug-in wizard. Once you have what you want in
the full Eclipse IDE then it's mostly a matter of removing stuff you don't
need for your custom IDE.
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"RD" <rajan11@hotmail.com> wrote in message news:c9qnic$dv2$1@eclipse.org...
> Hi All,
Re: Customized, Eclipse based IDE - How to start? [message #249858 is a reply to message #249837] Sat, 05 June 2004 06:15 Go to previous messageGo to next message
Thank you Ed. Let me start taking your suggestions. Let me see how it goes.
Re: Customized, Eclipse based IDE - How to start? [message #249985 is a reply to message #249760] Sun, 06 June 2004 22:23 Go to previous messageGo to next message
Originally posted by: cburleso.us.ibm.com
I would highly recommend that you do not embark upon such a journey
without "The Java Developer's Guide to Eclipse" at your side. This is a
book by Sherry Shavor, Jim D'Anjou, Scott Fairbrother, Dan Kehn, John
Kellerman, and Pat McCarthy. Most Barnes and nobles bookstores have it in
stock.
In particular, there is a whole chapter about creating editors. In
addition, there is a tutorial on creating a custom editor usng something
like SQL as an example language.
I have been just starting with Eclipse development and I know that I saved
hours of discovery and frustration becuase of this book. It's over 800
pages and covers some hidden tips on the use of eclipse as well as a
wealth of info (probably the most comprehensive available) on how to
program for it.
- Cody
Re: Customized, Eclipse based IDE - How to start? [message #250149 is a reply to message #249985] Mon, 07 June 2004 11:28 Go to previous messageGo to next message
> stock.
I have this book and find it interesting. As far as editor is concerned,
yes it has a very detailed example. But this book talks about Eclipse 2.1
(not a big problem though...). My main worry is not about writing an
editor, but is about packaging it.
When I package it finally for my end users, I don't want all the default
menu and toolbar actions. I want to define my own menu and tool bar as
well as perspectives. But at the same time I still need the functionality
of workbench and JDT. At this point I don't know how to do that.
> program for it.
Thanks for your response.
> Cheers,
> - Cody
Re: Customized, Eclipse based IDE - How to start? [message #250153 is a reply to message #249985] Mon, 07 June 2004 11:30 Go to previous message
> stock.
> program for it.
> Cheers,
> - Cody
Previous Topic:Supporting both 3.0 and 2.1.x?
Next Topic:[RC1]: How to use javadoc for a lib (jar).
Current Time: Sun Aug 31 23:33:20 EDT 2025
Powered by FUDForum. Page generated in 0.02999 seconds
