Home » Language IDEs » Java Development Tools (JDT) » IJavaElement from ITextSelection
IJavaElement from ITextSelection [message #249751] Wed, 21 November 2007 12:29 Go to next message
Hello all,
Is there a simple way of obtaining the IJavaElement associated with the
currently selected text? The only way I can accomplish this is using an
internal class, which I would like to avoid:
if (selection instanceof ITextSelection) {
ITextSelection textSelection = (ITextSelection) selection;
IWorkbenchPage activePage =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
if (activePage != null) {
IEditorPart editor = activePage.getActiveEditor();
if (editor instanceof CompilationUnitEditor) {
CompilationUnitEditor unitEditor = (CompilationUnitEditor) editor;
IJavaElement element = (IJavaElement) unitEditor.getViewPartInput();
In the above code, CompilationUnitEditor is internal. Any help would be
appreciated.
Jeff
Re: IJavaElement from ITextSelection [message #249757 is a reply to message #249751] Thu, 22 November 2007 03:31 Go to previous messageGo to next message
Jeffrey K. Czyz wrote:
> Hello all,
> the currently selected text? The only way I can accomplish this is
> using an internal class, which I would like to avoid:
I'm not sure about which CompilationUnitEditor you're talking about but
the one I know does not have a getViewPartInput() method. Anyway, what
you should use ist:
typeRoot= org.eclipse.jdt.ui.JavaUI.getEditorInputTypeRoot(IEditorInpu t)
typeRoot.codeSelect(selectionOffset, selectionLength)
Dani
> be appreciated.
> Jeff
Re: IJavaElement from ITextSelection [message #249828 is a reply to message #249757] Mon, 26 November 2007 14:44 Go to previous messageGo to next message
>> Hello all,
> you should use ist:
> Dani
Hi Dani,
Thanks for the reply. CompilationUnitEditor is a class in the internal
package org.eclipse.jdt.internal.ui.javaeditor. I wanted to avoid using it.
The example code you gave uses JavaUI.getEditorInputTypeRoot(IEditorInput),
which is new in Eclipse 3.4. Is there a different way of accomplishing this
using Eclipse 3.3?
Jeff
>> be appreciated.
>> Jeff
Re: IJavaElement from ITextSelection [message #249835 is a reply to message #249828] Tue, 27 November 2007 03:50 Go to previous messageGo to next message
>>> Hello all,
>>> editor;
>> but the one I know does not have a getViewPartInput() method. Anyway,
>> what you should use ist:
>> typeRoot=
>> Dani
> Hi Dani,
> internal package org.eclipse.jdt.internal.ui.javaeditor.
I know that. But this one does not have a getViewPartInput() method.
> JavaUI.getEditorInputTypeRoot(IEditorInput), which is new in Eclipse
> 3.4. Is there a different way of accomplishing this using Eclipse 3.3?
org.eclipse.jdt.ui.JavaUI.getEditorInputJavaElement(IEditorI nput)
Dani
> Jeff
>>> would be appreciated.
>>> Jeff
Re: IJavaElement from ITextSelection [message #249864 is a reply to message #249835] Tue, 27 November 2007 18:19 Go to previous message
>>>> Hello all,
>>>> editor;
>>> typeRoot=
>>> Dani
>> Hi Dani,
It is located in the super class (JavaEditor).
> Dani
Thanks, that did the trick.
Jeff
>> Thanks,
>> Jeff
>>>> Jeff
Previous Topic:Getting the exit code of a Launched Java process
Next Topic:Prevent lines from unwrapping in the formatter
Current Time: Fri Jul 18 01:44:38 EDT 2025
Powered by FUDForum. Page generated in 0.31634 seconds
