When rendering report with extended report item visitExtendedItem generates a null in 2.2. [message #249736] |
Wed, 25 July 2007 10:27  |
I have an extended report item that works with Birt 2.1.2. When I try
to use this same report item using the Birt 2.2 runtime to render a
report containing the new report item I get the following error.
org.eclipse.birt.report.engine.executor.ExecutorManager$Exec utorFactory.visitExtendedItem(ExecutorManager.java:274)
org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept( ExtendedItemDesign.java:37)
org.eclipse.birt.report.engine.executor.ExecutorManager$Exec utorFactory.createExecutor(ExecutorManager.java:246)
org.eclipse.birt.report.engine.executor.ExecutorManager.crea teExecutor(ExecutorManager.java:196)
org.eclipse.birt.report.engine.executor.ReportExecutor.getNe xtChild(ReportExecutor.java:114)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportExecutor.getNextChild(WrappedReportExecutor.java:64)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM$1.getN extChild(HTMLPageLM.java:59)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:125)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:84)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:90)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:148)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:71)
Any ideas. At this point it hasn't even executed any of the code in my
extended report item.
Any help would be appreciated.
Re: When rendering report with extended report item visitExtendedItemgenerates a null in 2.2. [message #250818 is a reply to message #250075] |
Wed, 01 August 2007 15:47  |
Sorry for the slow reply Scott.
Where would I find the new RotatedLabel example? I went back to
www.actuate.com/birt/contributions and that is still the old one.
Actuate is where I normally grab that example.
I also took a look in birt-sample-plugins-2_2_0.zip but that doesn't
seem to have the rotatedText example either.
Is it one of the other downloads off the Birt site?
Lester
Scott Rosenbaum wrote:
> Lester,
> I believe that the RotatedText has been updated in the most recent builds.
> Scott Rosenbaum
>> I fixed it and here is what I discovered.
>> So the documentation of the org.eclipse.birt.report.engine.extension
>> package says "Among the three interfaces, only IReportItemPresentation
>> is required, and the other two are optional" but this doesn't seem to
>> be the case, as my reportitem that is based off the RotatedLabel
>> example only implements the extension point for the presention but
>> blows up when the code tries to create a IReportItemGeneration
>> executor.
>> To solve I implemented the reportitemGeneration extension point and
>> pointed it to a class that extends ReportItemGenerationBase which
>> implements the IReportItemGeneration interface with empty methods and
>> voila it works.
>> So the documentation needs to be updated and the RotatedItemExample
>> needs to be modified.
>> Lester Mundt wrote:
>>> I have discovered that the rendering of my extended report item fails
>>> at
>>> IReportItemExecutor executor =
>>> ExtensionManager.getInstance().createReportItemExecutor(
>>> ExecutorManager.this, tagName );
>>> in Executormanage.visitExtendedItem()
>>> in turn this is becuase ExtensionManager.createReportItemExecutor
>>> calls IConfigurationElement config =
>>> (IConfigurationElement)generationExtensions.get( itemType );
>>> My extended item which is based off of the RotatedItem example
>>> extends the reportItemPresentation extension point rather than the
>>> reportItemGeneration extension point.
>>> This all used to work with 2.1.2 of course, so know I am wondering
>>> how I should change the code.
>>> 1. Should my extended report item also implement the
>>> reportItemGeneration extension point?
>>> 2. Should my extended report item only implement the
>>> 3. Is there a way when generating the reportdesign to add the fact
>>> that this extended item is in fact a reportItemPresentation?
>>> So could someone please provide some direction as to what I should do
>>> to correct this and perhaps some examples? Also does anyone know why
>>> this has changed this way?
>>> Thanks,
>>> Lester
>>>> try to use this same report item using the Birt 2.2 runtime to
>>>> render a report containing the new report item I get the following
>>>> error.
>>>> java.lang.NullPointerException
>>>> at
>>>> at
>>>> ItemDesign.java:37)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> eLM.java:84)
>>>> at
>>>> at
>>>> at
>>>> enderTask.java:71)
>>>> my extended report item.
FUDForum. Page generated in 0.26481 seconds
