Home » Archived » BIRT » [BIRT2.2.0] CSV Export Problems
[BIRT2.2.0] CSV Export Problems [message #249711] Wed, 25 July 2007 06:43 Go to next message
Hi there,
iŽm using birt 2.2.0 embedded in my web application on a Weblogic 8.1.5 .
Everything works fine, except the csv export:
1) birt exports the incorrect values, when exporting data from a simple
bar chart
2) export from a crosstab report doesnŽt work at all; the datacube canŽt
even be selected as a source in the export-window
I get the same result, when running my reports an a Tomcat and a Sun
AppServer, so the (unpopular) weblogic canŽt be the issue. I also consider
my reports as beeing correct.
Has anybody else experienced this kind of problems? IŽm grateful for every
hint!
Chris
Re: [BIRT2.2.0] CSV Export Problems [message #249936 is a reply to message #249711] Thu, 26 July 2007 05:18 Go to previous messageGo to next message
Hm, is there really no one else with this problem or at least a similar?
Re: [BIRT2.2.0] CSV Export Problems [message #249944 is a reply to message #249936] Thu, 26 July 2007 05:31 Go to previous messageGo to next message
Hi Chris,
What kind of incorrect values expoted from simple chart?
Currently the export data from crosstab are not supported.
Regards!
Re: [BIRT2.2.0] CSV Export Problems [message #249967 is a reply to message #249944] Thu, 26 July 2007 07:51 Go to previous message
Hi Tianli,
no export from crosstab, hmm bad about it, but not that big deal. i just
have to redesign a few reports. the false exported data from the chart was
caused by wrong data stored in the db (dŽoh!). this mistake wasnŽt obvious
when looking just at the chart... birt works fine.
anyway, thanks for the quick reply!
greets,
chris
Previous Topic:Cannot add Report Items in Header by using multiple masterpage
Next Topic:Birt Chart
Current Time: Mon Oct 27 08:15:07 EDT 2025
Powered by FUDForum. Page generated in 0.06165 seconds
