Home » Eclipse Projects » Eclipse Platform » Added Custom Text File Encoding to Eclipse
Added Custom Text File Encoding to Eclipse [message #249699] Fri, 04 June 2004 14:34
Originally posted by: eric.gameloft.com
I am attempting to get sjpp (https://sjpp.dev.java.net/) to work within
the Eclipse IDE. It is essentially allows java to support preprocessing
directives (#if, #else, etc) by adding a new encoding scheme.
It works fine when I compile java files using javac, however, I cannot
enable the encoding scheme in Eclipse (PREPROC). It always compains that
it is not a valid text encoding scheme.
To enable sjpp to work from a command line, I simply put the jar in
\java\jre\lib\ext. Is there a corresponding directory for Eclipse to
automatically make the encoding scheme available? An XML file?
Thanks is advanced.
Eric
Previous Topic:visibility of classes
Next Topic:NullPointerException when calling MyPlugin.find()
Current Time: Sat Aug 23 18:01:55 EDT 2025
Powered by FUDForum. Page generated in 0.03898 seconds
