Home » Archived » BIRT » Display date in report parameter window
Display date in report parameter window [message #249692] Wed, 25 July 2007 03:57 Go to next message
Originally posted by: aaa.aaa.it
trying to display a default value for a date in report parameter window
I wrote (INITIALIZE):
var cal = java.util.Calendar.getInstance();
var parseMe = new java.text.SimpleDateFormat("d/MM/y");
var dateValue = parseMe.parse("01/01/" + cal.get(java.util.Calendar.YEAR));
params["myDate"].value = dateValue;
params["myDate"].displayText = dateValue.toString();
myDate is a String format parameter.
When I launch the report and I display "Show report parameters"
I don't see my field filled with the expected value.
Something conceptually wrong in my code?
Bye,
nic
Re: Display date in report parameter window [message #249777 is a reply to message #249692] Wed, 25 July 2007 12:21 Go to previous message
Nic,
The issue is that initialize is called later than code that reads the
parameter values.
Take a look at this wiki entry for a work around.
http://wiki.eclipse.org/Dynamic_Default_Values
Jason
Nico wrote:
> Bye,
> nic
Previous Topic:Data filtering
Next Topic:load a report library through a JavaScript handler
Current Time: Sat Nov 08 08:20:34 EST 2025
Powered by FUDForum. Page generated in 0.02824 seconds
