Home » Eclipse Projects » Eclipse Platform » Debug mode doesn't run program
Debug mode doesn't run program [message #249680] Fri, 04 June 2004 14:22 Go to next message
Originally posted by: dlaub.wheels.com
After debug mode working perfectly for a while (e.g. program execution stops
at breakpoints), it appears that programs are not running at all when run in
debug mode (the breakpoints are never hit, no noticeable program execution
occurs. I do see a new "thread' of execution (e.g. console shows
localhost:99999, but the console window is empty) Also, the debug commands
(e.g. step into) remained grayed out on the Run menu. Right before debug
stopped working I did see an error message complaining about the VM/JRE call
stack being invalid - but rebooting my PC does nothing to fix this problem.
The programs continue to run correctly in non-debug mode. I'm running
Windows XP by the way.
Any help would be appreciated.
Re: Debug mode doesn't run program [message #249716 is a reply to message #249680] Fri, 04 June 2004 14:57 Go to previous message
I'm a newbie/idiot - All I needed was to switch to debug view (which
apparently happend automagically before)
"David Laub" <dlaub@wheels.com> wrote in message
news:c9qe5t$3a8$1@eclipse.org...
stops
in
commands
call
problem.
Previous Topic:NullPointerException when calling MyPlugin.find()
Next Topic:Migrating a 2.1 plugin to 3.0
Current Time: Tue Nov 04 13:13:42 EST 2025
Powered by FUDForum. Page generated in 0.02967 seconds
