Home » Eclipse Projects » GEF » [Draw2D] Text figure with getLocationAtOffset
[Draw2D] Text figure with getLocationAtOffset [message #249605] Mon, 13 July 2009 20:44 Go to next message
Hello.
Is there a text figure that supports something like getLocationAtOffset?
I provide the character offset as parameter and want the x and y coordinates.
Or any other solutions to get a specific text position inside a figure that supports text?
Kai
Re: [Draw2D] Text figure with getLocationAtOffset [message #249610 is a reply to message #249605] Mon, 13 July 2009 20:58 Go to previous messageGo to next message
A solution could be TextFlow.getCarePlacement if I understand the API documentation correctly.
What I want to do is to mark up specific strings inside a text, like StyledText with it StyleRange's
does. Is this possible with Draw2D?
Are there any examples how to use the stuff in org.eclipse.draw2d.text?
Kai
Kai Schlamp wrote:
> Hello.
> coordinates.
> that supports text?
> Kai
Re: [Draw2D] Text figure with getLocationAtOffset [message #249618 is a reply to message #249610] Tue, 14 July 2009 07:28 Go to previous messageGo to next message
No, getCaretPlacement did not help. Any other way to get the positions coordinates of an offset
inside a TextFlow?
Kai
Re: [Draw2D] Text figure with getLocationAtOffset [message #249623 is a reply to message #249618] Tue, 14 July 2009 15:49 Go to previous message
Ok, I solved that problem by adding a layout listener to the TextFlow. After the TextFlow was layout
(method postLayout) I can use the getCaretPlacement method and get the correct offset locations (but
strangely only when the text ends with \n).
> coordinates of an offset inside a TextFlow?
> Kai
Previous Topic:Exporting RCP GEF Editor
Next Topic:[Draw2D] TextFlow an setSelection
Current Time: Tue Jul 15 17:08:35 EDT 2025
Powered by FUDForum. Page generated in 0.08571 seconds
