Home » Newcomers » Newcomers » C++ Compilers which work with Eclipse
C++ Compilers which work with Eclipse [message #249601] Thu, 21 February 2008 01:38 Go to next message
Originally posted by: volunteer.bokss.org.hk
What is your personal choice of C++ compiler(s) which work(s) with Eclipse?
MingGW, gnu or any others? Can I use MS Visual compilers with Eclipse?
Jack
Re: C++ Compilers which work with Eclipse [message #249927 is a reply to message #249601] Fri, 22 February 2008 22:14 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Hi Jacky, I think you can use the MS compilers, however, this question
is probably better addressed on the CDT newsgroup. That newsgroup is
only about C/C++ tooling for eclipse.
cheers
ian
Jacky Luk wrote:
> Thanks
> Jack
Re: C++ Compilers which work with Eclipse [message #249935 is a reply to message #249601] Sat, 23 February 2008 00:33 Go to previous message
Originally posted by: jim.marshall.wbemsolutions.com
Jacky Luk wrote:
> Thanks
> Jack
CDT is designed to use GCC (MinGW or Cygwin). Out of the "box" CDT will
not use MS compilers.
Previous Topic:Problem Opening Eclipse
Next Topic:Generate class file with lower-case file name
Current Time: Fri Nov 07 13:35:29 EST 2025
Powered by FUDForum. Page generated in 0.08661 seconds
