Home » Eclipse Projects » GEF » Label parallel to Connection
Label parallel to Connection [message #249593] Mon, 13 July 2009 11:13 Go to next message
I use GMF to create a graphical editor, I have Label with icon in the
middle of my connections, my connections don't have bendpoints.
Then I want my label be parallel to my connection. I can probably use
Transform draw2d class to keep my label rotation angle identical to my
connection rotation angle, but I don't see how to use Transform draw2d
class.
There is a example of his use?
Thanks.
Re: Label parallel to Connection [message #249602 is a reply to message #249593] Mon, 13 July 2009 11:56 Go to previous messageGo to next message
There is a method on ConnectionEditPart: installBendpointEditPolicy() that
I'd suggest to override, but it's private. Please raise a bug and we'll
change it's visibility.
Alex
Re: Label parallel to Connection [message #249642 is a reply to message #249602] Wed, 15 July 2009 02:34 Go to previous messageGo to next message
Alex Boyko a écrit :
> that I'd suggest to override, but it's private. Please raise a bug and
> we'll change it's visibility.
> Cheers,
> Alex
Hi Alex,
I don't know how I can do what I want by overriding
ConnectionEditPart.installBendpointEditPolicy().
Otherwise I should be able to override previously installed
EditPolicy.CONNECTION_BENDPOINTS_ROLE EditPolicy with following code :
installEditPolicy(EditPolicy.CONNECTION_BENDPOINTS_ROLE, new
NullConnectionBendPointEditPolicy());
but this code don't have effect.
Thanks Alex.
Re: Label parallel to Connection [message #249652 is a reply to message #249642] Wed, 15 July 2009 06:07 Go to previous messageGo to next message
Have a look at https://bugs.eclipse.org/bugs/show_bug.cgi?id=281246
Mariot
>> Cheers,
>> Alex
> Hi Alex,
> Thanks Alex.
Re: Label parallel to Connection [message #249695 is a reply to message #249652] Wed, 22 July 2009 14:08 Go to previous message
Hi Mariot,
Thanks for your tip, now I can do it with GEF but I can't do it with GMF
(see news://news.eclipse.org:119/h3q0kl$p43$1@build.eclipse.org).
Thanks.
Previous Topic:Object creation with DnD from the palette prevent direct edit
Next Topic:How to run a project
Current Time: Mon Nov 03 07:10:42 EST 2025
Powered by FUDForum. Page generated in 0.04662 seconds
