Home » Language IDEs » Java Development Tools (JDT) » Problem with Dislay window while debugging
Problem with Dislay window while debugging [message #249446] Fri, 09 November 2007 07:16
I wonder if someone can help me. I am using eclipse 3.3.1.1
M20071023-1652 and remote debugging a web app deployed on Tomcat 6.0.14.
I have the spring 2.0.7 jar on the build path and I have the source
attached. I can hit break points in the spring source files and the
variables window shows all the variables correctly but when I try to
"Inspect" or "Display" in the Display window I get the following message:
Evaluation failed. Reason(s):
Unable to evaluate the selected expression:
To perform an evaluation, an expression must be compiled in the context
of a Java project's build path. The current execution context is not
associated with a Java project in the workspace.
Can someone please tell what I have to do to get this working. I am
pretty sure I could do this in eclipse 3.2.
Previous Topic:javadoc for plug-in not working
Next Topic:JDTCompilerAdapter, srcdir with spaces
Current Time: Fri Sep 19 04:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.02632 seconds
