Home » Language IDEs » Java Development Tools (JDT) » javadoc for plug-in not working
javadoc for plug-in not working [message #249337] Tue, 06 November 2007 12:59 Go to next message
I posted this message in the newcomers group before, but got no answer. As
this might be a little too deep for newcomers, I thought I'd post it here
instead. Hope this is the correct group to answer this.
I have problems getting javadoc (shift-F2) to work for some plugins. For
some plugins it works (e.g. org.eclipse.ui.editors), and for some others
it doesn't (e.g. for org.eclipse.draw2d).
I have discovered the difference in:
Project->properties->Java Build Path->Libraries
The ones that do not work do not have a JavaDoc location. However, Eclipse
does not allow me to set the JavaDoc location for those plugins that don't
work (non-modifiable). Another way to set the Javadoc location would be to
edit the properties of the plug-in in the Package Explorer view. But the
pop.up there says:
"The current class path entry belongs to the container 'Plug-in
Dependencies' which does not allow user modifications to Javadoc locations
on its entries"
If have searched the documentation and newsgroups for a solution but could
not find one.
How do I set the javadoc location for plug-ins ?
Thanks!
Rene
Re: javadoc for plug-in not working [message #249340 is a reply to message #249337] Wed, 07 November 2007 06:20 Go to previous messageGo to next message
> answer. As this might be a little too deep for newcomers, I thought
> I'd post it here instead. Hope this is the correct group to answer this.
> For some plugins it works (e.g. org.eclipse.ui.editors), and for some
> others it doesn't (e.g. for org.eclipse.draw2d).
> Eclipse does not allow me to set the JavaDoc location for those
> plugins that don't work (non-modifiable). Another way to set the
> Javadoc location would be to edit the properties of the plug-in in the
> Package Explorer view. But the pop.up there says:
> locations on its entries"
> could not find one.
First of all you should check your installation and if it is OK then
file a bug report against the plug-in that isn't correctly setup. If you
want to fix this yourself simply import those projects as binary
projects into your workspace. You can then modify the Javadoc and source
attachments.
Dani
> Thanks!
> Rene
Re: javadoc for plug-in not working [message #249444 is a reply to message #249340] Thu, 08 November 2007 15:57 Go to previous message
>> could not find one.
> attachments.
> Dani
Thanks very much for the help, Dani. importing the plug-ins and setting
the javadoc path directly did the trick. It turned out the troublesome
plugins (gef and draw2d) did not have Javadoc included, but instead
delivered a separate "doc" plugin. So it may not have been a bug but a
"feature". Anyway, I will try to issue a bug report
Thanks, Rene
Previous Topic:Help Viewer Error
Next Topic:Problem with Dislay window while debugging
Current Time: Thu Nov 06 05:50:50 EST 2025
Powered by FUDForum. Page generated in 0.03127 seconds
