Home » Eclipse Projects » GEF » Create a figure without model representation in an existing GEF editor
Create a figure without model representation in an existing GEF editor [message #249235] Thu, 11 June 2009 03:45 Go to next message
Originally posted by: alexia.allanic.atosorigin.com
I want to create for a GEF editor without modifying it an action which
can add a figure (for example a rectangle).
I don't want to add my action in the palette but if possible in a menu.
The figure created doesn't have to be persisted in the diagram file.
Is This kind of action is possible ? And how can i realize it ?
Alexia
Re: Create a figure without model representation in an existing GEF editor [message #249267 is a reply to message #249235] Fri, 12 June 2009 21:01 Go to previous messageGo to next message
You can certainly write an action that will just add a Figure without a
backing edit part or model. But then you will have to manage the state
of that figure yourself. Might be easier to use a model, but tweak
whatever serializes your model to not serialize that object. Perhaps
you would like to elaborate on the use case a bit?
Regarding the action itself, just read the platform developer guide on
how to put actions in menus. Then instantiate your action such that it
knows how to get a handle to the graphical viewer. The DeleteAction that
the Logic Example uses is one example of how to hook up a GEF type of
action.
Hope that helps
Ben
ALLANIC Alexia wrote:
> Regards
> Alexia
Re: Create a figure without model representation in an existing GEF editor [message #249285 is a reply to message #249267] Mon, 15 June 2009 06:01 Go to previous messageGo to next message
I have many GEF editors and I want to add a generic action which permits
to add a figure which mustn't be add on the model, the diagram file.
> action.
> Hope that helps
> Ben
>> Regards
>> Alexia
Re: Create a figure without model representation in an existing GEF editor [message #249303 is a reply to message #249285] Tue, 16 June 2009 05:32 Go to previous message
HI !
i work in the same team as Alexia
Actually we have a plugin which works with some Gef editors : GMF ...
we want to add a menu which permit to add a rectangle on any diagram
working for our plugin.
We have some possibilites :
1) designing a top level generic plugin which only works with gef
possibilites
2) designing a plugin with specific editor capacities
in both way we don't know how to add dynamically a figure which is not
expected by current editor
if somebody has a solution it could be a pleasure :)
Tristan FAURE
ALLANIC Alexia a écrit :
> permits to add a figure which mustn't be add on the model, the diagram
> file.
>> a backing edit part or model. But then you will have to manage the
>> state of that figure yourself. Might be easier to use a model, but
>> tweak whatever serializes your model to not serialize that object.
>> Perhaps you would like to elaborate on the use case a bit?
>> on how to put actions in menus. Then instantiate your action such
>> that it knows how to get a handle to the graphical viewer. The
>> DeleteAction that the Logic Example uses is one example of how to
>> hook up a GEF type of action.
>> Hope that helps
>> Ben
>>> Hi,
>>> which can add a figure (for example a rectangle).
>>> Regards
>>> Alexia
Previous Topic:Connect nodes via keyboard
Next Topic:[Announce] GEF 3.5.0 I200906051552 is available
Current Time: Sun Nov 09 04:22:46 EST 2025
Powered by FUDForum. Page generated in 0.03345 seconds
