API to find out about available JDT packages/classes in a project [message #249226] |
Sun, 04 November 2007 13:35  |
Hi All,
I'd like to know if there's some public API to find out about the
available packages/classes within a given Java Project classpath entry.
I'm trying to integrate code-completion in Pydev using JDT... I've already
done it for external jars, but I do the jar traverse in pydev to know the
module names/classes and use the JDT code-completion engine for actually
getting the completions for a type which is already know at that point --
but for a given JDT project, calculating the packages/classes in my plugin
doesn't seem right.
It seems that the code below is able to do what I want, but it is
JDT-internal code... is there any other way to get it?
//create a unit with the parts of the classpaths we're interested in...
ICompilationUnit unit = new WorkingCopyOwner(){}.newWorkingCopy("Temp",
classpathsArray, new NullProgressMonitor());
//cast to a java project (that has the newNameLookup)
org.eclipse.jdt.internal.core.JavaProject j = (JavaProject) javaProject
org.eclipse.jdt.internal.core.NameLookup n = j.newNameLookup(new
ICompilationUnit[]{unit});
//use name lookup seek methods to get the classes/packages.
It also appears that using JavaProject.newSearchableNameEnvironment()
works, but it's also not public...
So, any 'public' ways to get that info?
Fabio
Re: API to find out about available JDT packages/classes in a project [message #249343 is a reply to message #249226] |
Wed, 07 November 2007 13:30   |
Anyone? (I'm still looking into this)...
Fabio
Fabio Zadrozny wrote:
> Hi All,
> doesn't seem right.
> Fabio
Re: API to find out about available JDT packages/classes in a project [message #249470 is a reply to message #249344] |
Sat, 10 November 2007 06:54  |
Hi Olivier,
Actually, I've tried that approach, but I wanted to be able to get only a
part of the package fragments for the given project
(org.eclipse.jdt.core.IJavaProject#getPackageFragments() will return all
the package fragments from the project + system + deps), which is not
really what I want... I want to be able to get the packages from a given
IClassPathEntry (usually starting with a given string). So far I've only
been able to do that efficiently using the internal API...
I've just found out about findPackageFragmentRoots(entry) and it may be
able to do what I want -- not sure if it'll be as efficient as the
internal API, as I'll have to get each package name to do the filtering,
but it may be able to do it -- will check a bit further on this approach...
Thanks for your support,
Fabio
Olivier Thomann wrote:
> Do you want the package as IPackageFragment ?
> If yes, you can org.eclipse.jdt.core.IJavaProject#getPackageFragments().
> Once you have the IPackageFragments elements, you can iterate over them
> to collect the compilation units using:
> org.eclipse.jdt.core.IPackageFragment#getCompilationUnits().
> Does this answer the question?
> Olivier
FUDForum. Page generated in 0.03230 seconds
