Home » Newcomers » Newcomers » 'Data' View Selection not displayed
'Data' View Selection not displayed [message #249106] Fri, 15 February 2008 17:51 Go to next message
Originally posted by: rojiru.c.gmail.com
I've installed Eclipse 3.3 on winxp, vista and ubuntu. The installs pretty
much finish without any problems. I've added some plugins and the updates
as per the documentation that I have read. I have phpeclipse installed
using the nightly builds.
The problem is that in the 'Show View' dialog window, the 'Data' selection
is not displayed. This is the case across all 3 os's used above. There may
be something that I have not installed. Any help is greatly appreciated.
roger
Re: 'Data' View Selection not displayed [message #249191 is a reply to message #249106] Mon, 18 February 2008 09:59 Go to previous message
> pretty much finish without any problems. I've added some plugins and the
> updates as per the documentation that I have read. I have phpeclipse
> installed using the nightly builds.
> selection is not displayed. This is the case across all 3 os's used
> above. There may be something that I have not installed. Any help is
I'm not positive, but I think the data tools plugins require Eclipse to
be running on Java 5 or higher. Use Help > About > Configuration Details
to determine exactly what JVM Eclipse is in; if it is not 5.0/1.5 then
you need to specify the proper JVM, as instructed here:
http://wiki.eclipse.org/Eclipse.ini
Hope this helps,
Eric
Previous Topic:Eclipse Europa hangs when launching editor
Next Topic:How to get the icon of the local folder or disk in SWT
Current Time: Wed Dec 03 09:20:06 EST 2025
Powered by FUDForum. Page generated in 0.09601 seconds
