Home » Eclipse Projects » Eclipse Platform » RC1 still a bit slow at times..
RC1 still a bit slow at times.. [message #249082] Thu, 03 June 2004 16:06 Go to next message
I notice several times in a session over a period of hours, that Eclipse
just sort of takes over the cpu. For example, I'll open a file to start
editing..it opens. Then when I click in the editor it just seems to hang for
a minute or so. Finally it comes back. I'll expand a project, then shrink
it, and it suddenly just seems to hang. Even clicking on other running apps
just seem to flash their taskbar button and not bring them forward. I am
guessing the GC is running? But I have 1GB of memory!! It shows that I have
over 600MB free memory, so I can't imagine why this is?
C:\java\eclipse\eclipse.exe -vmargs -Xverify:none
That is my start sequence. Should I add anything to increase memory? I
actually thought I had the xMx argument, but not sure if that is needed now?
Re: RC1 still a bit slow at times.. [message #249088 is a reply to message #249082] Thu, 03 June 2004 16:21 Go to previous messageGo to next message
Probably GCing. Try -vmargs -Xmx256m
-e
Re: RC1 still a bit slow at times.. [message #249093 is a reply to message #249088] Thu, 03 June 2004 16:29 Go to previous messageGo to next message
But this still doesn't fix the problem why eclipse slow starts eating and eating memory..
When i start it first and it si completely loaded and the workspace fully build it uses this:
[Full GC 42610K->30398K(64960K), 0.5407743 secs]
so after a GC it only uses 30MB with a total heap of 64 (the size i start with)
But after a few hours this is multiplied by 4 (uses mem and heap size)
I do find this a bit strange.
johan
> -e
>> hang for
>> apps
>> have
>> needed now?
Re: RC1 still a bit slow at times.. [message #249103 is a reply to message #249093] Thu, 03 June 2004 16:44 Go to previous messageGo to next message
It is piggish with memory, but RC1 is much improved for me in that
regard, and I think that it is one of the issues they hope to address
prior to the final release.
> and eating memory..
> start with)
> johan
>> -e
>>> hang for
>>> shrink
>>> running apps
>>> I have
>>> needed now?
Re: RC1 still a bit slow at times.. [message #249194 is a reply to message #249103] Thu, 03 June 2004 23:53 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
You'll still always need the -vmargs -Xmx256m (change 256 to whatever
maximum heap size in megabytes that works for you) if using the Sun VM (at
least for version 1.4). We have asked for the default to be increased but
currently the argument against it is that the option is VM specific and they
want to be VM independent, and also that RCP applications might not need
more than the 64M default maximum. See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24512
https://bugs.eclipse.org/bugs/show_bug.cgi?id=50218
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"exquisitus" <user@domain.invalid> wrote in message
news:c9o24t$b5h$1@eclipse.org...
> > and eating memory..
> > start with)
> > johan
Re: RC1 still a bit slow at times.. [message #249198 is a reply to message #249194] Fri, 04 June 2004 00:44 Go to previous messageGo to next message
Originally posted by: rtayek.no.spam.freightgate.com
"Ed Burnette" <ed.burnette@REMOVE.THIS.sas.com> wrote in message
news:c9or9q$2h8$1@eclipse.org...
how does one find out what this is set to (in eclipse) and how does one
change it?
does anyone know what a good maximum setting is as a function of physical
ram size?
thanks
Re: RC1 still a bit slow at times.. [message #249277 is a reply to message #249198] Fri, 04 June 2004 06:46 Go to previous messageGo to next message
> change it?
> ram size?
It should rather be a function of the number of opened projects you want
to have, a function of the number of objects in your java model, the
needs of the plugins you use.
Alternativly, you might find useful the MemoryManager plugin (see
eclipse-plugins.info)
> thanks
Re: RC1 still a bit slow at times.. [message #249822 is a reply to message #249198] Fri, 04 June 2004 20:15 Go to previous messageGo to next message
It is set on the command line (-vmargs option) when invoking Eclipse, not
inside Eclipse. You want to set it as small as you can get away with without
excessive garbage collection. The default for Sun's JVM is 64M. The Eclipse
3.0 IDE needs at least 128M, and for my mix of work I use 256M or 300M.
YMMV.
Ed
"Ray Tayek" <rtayek.no@spam.freightgate.com> wrote in message
news:c9otvr$4do$1@eclipse.org...
> change it?
> ram size?
Re: RC1 still a bit slow at times.. [message #250272 is a reply to message #249822] Mon, 07 June 2004 17:06 Go to previous messageGo to next message
news:c9r2sf$ot7$1@eclipse.org...
without
Eclipse
> YMMV.
great! - this is exactly what i need to know.
thanks
> > change it? ...
Re: RC1 still a bit slow at times.. [message #250796 is a reply to message #249194] Wed, 09 June 2004 02:48 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
So they keep the default where it will cause problems for the majority.
Interesting choice.
Bob Foster
http://xmlbuddy.com/
they
> > > and eating memory..
> > > start with)
> > > johan
Re: RC1 still a bit slow at times.. [message #251071 is a reply to message #250796] Wed, 09 June 2004 12:04 Go to previous messageGo to next message
Interesting that there wasn't a bug report for it. So, I created one.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=66341 and vote for it.
> Interesting choice.
> Bob Foster
> they
>>>>and eating memory..
>>>>start with)
>>>>johan
Re: RC1 still a bit slow at times.. [message #252522 is a reply to message #251071] Mon, 14 June 2004 18:32 Go to previous message
Made me look :)
Ed
news:ca7bvr$li4$1@eclipse.org...
Previous Topic:Eclipse M9 plugin classnotfoundexception when using external jar
Next Topic:RCP tutorial1 startup problems
Current Time: Thu Oct 30 18:26:10 EDT 2025
Powered by FUDForum. Page generated in 0.04699 seconds
