| RCP - problem when help in separate plugin [message #249073] |
Thu, 03 June 2004 15:56  |
Originally posted by: steve.walton.us.ibm.com
In an RCP application, help is not working if table of contents and help
documents are in a separate plugin.
Is this a known issue for an RCP app?
To prove this have -
1) Copied the help plugin in full Eclipse and it works.
2) Have modified the application's plugin.xml to extend
"org.eclipse.help.toc" and copied the help TOC and documents into the
application's plugin and it works.
It simply does not work if help is in its own plugin.
Also, have checked the .log file and it gives little help:
!ENTRY org.eclipse.help.ui 4 0 Jun 03, 2004 15:42:58.121
!MESSAGE Documentation is not installed.
| Re: RCP - problem when help in separate plugin [message #249558 is a reply to message #249073] |
Fri, 04 June 2004 10:55  |
Originally posted by: dorian.birsan.net
"Steve Walton" <steve.walton@us.ibm.com> wrote in message
news:c9nvb6$80q$1@eclipse.org...
If you move the docs (doc.zip or the html files if not zipped) to another
plugin, you will have to adjust the href attributes in the corresponding
toc.xml files. Check the online help for what the cross plugin format is for
href (if I remember correctly, this is /other_plugin_id/path/to/file.html,
so you need to prepend /other_plugin_id/ to each href in the toc.xml files).
FUDForum. Page generated in 0.06063 seconds
