Home » Eclipse Projects » GEF » Feedback layer zoom
Feedback layer zoom [message #248967] Wed, 13 May 2009 11:19 Go to next message
Hello
I have modified the standard Resize policy to be able to rotate figures.
During rotate I am not using the standard Ghost shape, but I am rotating
cloned shape so user can directly see positioning of the shape.
My problem is that when the zoom is on (let's say 200%) then when creating
this clone it gets created in standard size. I have a dumb solution which
I don't like.
My question is:
How can I turn on the ZOOM for the feedback layer? (When I look into the
SWTGraphics property of the feedback layer it says that zoom is "1" and
all the other layer have zoom "2"). If I could turn on the zooming of the
feedback layer all my troubles would be gone.
Thanks!
Tomas
Re: Feedback layer zoom [message #248976 is a reply to message #248967] Wed, 13 May 2009 21:15 Go to previous messageGo to next message
I assume that if you just use the standard ghost shape then this is not
a problem? I don't think its a matter of layers, its probably how you
are specifying the bounds of your feedback figure. I suspect there is a
scaling or coordinates translation step missing..
Just throwing some ideas out there. Hope it helps.
-Ben
Tomas Trescak wrote:
> Hello
> creating this clone it gets created in standard size. I have a dumb
> solution which I don't like.
> My question is:
> the feedback layer all my troubles would be gone.
> Thanks!
> Tomas
Re: Feedback layer zoom [message #503265 is a reply to message #248967] Fri, 11 December 2009 06:10 Go to previous message
Originally posted by: carsten.labinsky.de
Hello Tomas --
I have the same problem. Did you find a solution for it?
Carsten
> Hello
> My question is:
> Thanks!
> Tomas
Previous Topic:[RESOLVED] How to add SelectionListener on a PaletteEntry
Next Topic:Outline view and EMF+GEF+MultiPageEditor
Current Time: Thu Nov 06 17:26:24 EST 2025
Powered by FUDForum. Page generated in 0.03334 seconds
