Home » Archived » OHF » error when uploading documents
error when uploading documents [message #24487] Fri, 24 November 2006 21:17 Go to next message
I'm trying to get document uploads on our bridge client working using
WrapInCdaAndSubmitDocument, but I'm getting this error each time:
java.lang.IllegalArgumentException: argument type mismatch
I can't find where in the stack trace it specifies exactly what the
mismatch is, so I'm having considerable trouble tracking it down. How
can I find out?
Thanks!
-Dan
Re: error when uploading documents [message #24528 is a reply to message #24487] Sat, 25 November 2006 02:54 Go to previous messageGo to next message
Originally posted by: eishays.us.ibm.com
Tim reported it also (bug #165582).
Fixed (was a really strange eclipse env thing :-).
--eishay
> can I find out?
> Thanks!
> -Dan
Re: error when uploading documents [message #24672 is a reply to message #24528] Sun, 26 November 2006 17:21 Go to previous messageGo to next message
> --eishay
>> can I find out?
>> Thanks!
>> -Dan
Hmm... I'm still not having success. I wonder what's wrong with my
implementation of the API. I haven't submitted a bug report yet because
I suspect it's something on my end (I based my code on the php bridge
client demo but I've made a lot of changes to try to fit the new api).
The only information I have to go on is the stack trace I get back in
the error report, but that only traces my end. I've looked over the api
and I can't find where I'm doing it wrong.
What would really help me is if the server or someone with the right
knowledge could tell me more about the problem. If they could tell me
what argument, and in what function, I might be able to track it down a
little better.
I'm using the ibmod235-all RHIO, logged in as "dhale", facility "Test
Land Medical Clinic", session id "bbd9a6c000fb96151ef68243160ff4e3",
application "openEMR".
Here's a section of the stack trace (on my end) that displays the
parameters I'm passing into WrapInCdaAndSubmitDocument. I think they're
right but I'd appreciate it if anyone could point out what's wrong.
[0]=>
string(26) "WrapInCdaAndSubmitDocument"
[1]=>
array(2) {
["sessionContext"]=>
&object(sessioncontext)(7) {
["user"]=>
string(5) "dhale"
["sessionID"]=>
string(32) "bbd9a6c000fb96151ef68243160ff4e3"
["rhioName"]=>
string(12) "ibmod235-all"
["userApplicationName"]=>
string(7) "openEMR"
["userFacilityName"]=>
string(24) "Test Land Medical Clinic"
["returnLogLevel"]=>
string(5) "DEBUG"
["useSecuredConnectionWhenAvaliable"]=>
bool(false)
["doc"]=>
&object(xdsdoctype)(11) {
["base64EncodedDocument"]=>
string(306788) (skipped because it's too long)
["decodedDocument"]=>
NULL
["documentSize"]=>
int(230091)
["documentTitle"]=>
string(15) "A Test Document"
["effectiveTime"]=>
NULL
["encodingType"]=>
string(3) "B64"
["formatCode"]=>
NULL
["mimeType"]=>
string(15) "application/pdf"
["patientInfo"]=>
object(patientinfotype)(7) {
["patientIdentifier"]=>
object(patientidtype)(2) {
["idNumber"]=>
string(10) "JM19400814"
["assigningAuthorityType"]=>
object(assigningauthoritytype)(5) {
["namespaceId"]=>
string(9) "HIMSS2005"
["universalId"]=>
string(26) "1.3.6.1.4.1.21367.2005.1.1"
["universalIdType"]=>
string(3) "ISO"
["universalIdTypeCode"]=>
string(0) ""
["useDefaultAssigningAuthority"]=>
NULL
["patientName"]=>
object(patientnametype)(5) {
["familyName"]=>
string(6) "Murphy"
["givenName"]=>
string(5) "Joyce"
["otherName"]=>
string(5) "Marie"
["suffix"]=>
string(0) ""
["prefix"]=>
string(0) ""
["patientDateOfBirth"]=>
string(0) ""
["patientSex"]=>
string(0) ""
["patientAddress"]=>
object(addresstype)(7) {
["streetAddress"]=>
string(12) "903 Susan Pl"
["otherDesignation"]=>
string(0) ""
["city"]=>
string(8) "Lacrosse"
["stateOrProvince"]=>
string(2) "WI"
["zipOrPostalCode"]=>
string(5) "54603"
["country"]=>
string(0) ""
["countyParishCode"]=>
string(0) ""
["patientPhoneHome"]=>
object(phonetype)(1) {
["unformattedTelephoneNumber"]=>
NULL
["patientPhoneBusiness"]=>
NULL
["uniqueId"]=>
NULL
["uuid"]=>
NULL
Re: error when uploading documents [message #24712 is a reply to message #24672] Sun, 26 November 2006 20:53 Go to previous messageGo to next message
Hi Dan,
The problem is probably in the usage of the WrapInCdaAndSubmitDocument
method.
We didn't mentioned this method in our documentation on purpose:
http://wiki.eclipse.org/index.php/OHF_Bridge_Documentation
WrapInCdaAndSubmitDocument is deprecated since you can't use it to pass
the Connectathon tests and NHIN. The method gives too much control over
the metadata to the bridge. We also didn't test our PHP samples that
works with it yet since the API change.
Please use SubmitDocument (see
http://wiki.eclipse.org/index.php/OHF_Bridge_Documentation). The method
passed the NIST testes with the NIST server.
--eishay
Re: error when uploading documents [message #24751 is a reply to message #24712] Mon, 27 November 2006 16:04 Go to previous messageGo to next message
Eishay Smith wrote:
> Hi Dan,
> method.
> --eishay
Okay, that does make sense.
I've just now switched functions, set up the parameters differently etc
(and trying to upload a pre-made CDA, scanSample.xml), and it seems to
be almost finishing successfully. However, it fails with a SOAP Fault.
Here's the section of the log where it fails (I can provide more if
needed, including the full response object).
Something is trying to read a null stream ("Error reading data stream:
null"); The fault starts on line 35, but I'm including a bit above in
case it's pertinent:
[29] => 2006-11-27T14:33:49.531-06:00 Sending Audit
message: <13>Nov 27 14:33:49 198.81.193.235 <?xml version="1.0"
encoding="ASCII"?><AuditMessage
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="healthcare-security-audit.xsd "><AuditSourceIdentification
AuditSourceID="198.81.193.235"/><EventIdentification EventActionCode="E"
EventDateTime="2006-11-27T14:33:49.531-06:00"
EventOutcomeIndicator="0"><EventID code="110100" codeSystemName="DCM"
displayName="Application Activity"/><EventTypeCode code="110120"
codeSystemName="DCM" displayName="Application
Start"/></EventIdentification><ActiveParticipant UserID="dhale"
UserIsRequestor="true"><RoleIDCode code="110152" codeSystemName="DCM"
displayName="Destination"/></ActiveParticipant><ActiveParticipant
UserID=" http://ibmod235.dal-ebis.ihost.com:9080/IHIIRepository/Submi ssionSetReceiver"
UserIsRequestor="false"><RoleIDCode code="110153" codeSystemName="DCM"
displayName="Source"/></ActiveParticipant></AuditMessage >
[30] => Log overflow, the log was trimmed since it is to
large to send in one message
[31] => 2006-11-27T14:33:49.547-06:00 Submission set
contains no folders.
[32] => Log overflow, the log was trimmed since it is to
[33] => 2006-11-27T14:33:49.547-06:00 Submitting Provide
and Register Document Set transaction to Repository:
[34] => Log overflow, the log was trimmed since it is to
[35] => 2006-11-27T14:34:50.783-06:00 SOAP FAULT
[36] => Log overflow, the log was trimmed since it is to
[37] => 2006-11-27T14:34:50.783-06:00 Fault Message:<?xml
version="1.0" encoding="UTF-8"?><soapenv:Envelope
xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <soapenv:Body>
<soapenv:Fault> <faultcode
xmlns:ns1="http://xml.apache.org/axis/">ns1:HTTP</faultcode>
<faultstring>(500)Internal Server Error</faultstring> <detail>
<string>return code: 500Error 500: SOAP POST failed: WSWS3259E: Error:
Error reading data stream: null</string> <ns2:HttpErrorCode
xmlns:ns2="http://xml.apache.org/axis/">500</ns2:HttpErrorCode>
</detail> </soapenv:Fault> </soapenv:Body></soapenv:Envelope>
[38] => Log overflow, the log was trimmed since it is to
[39] => 2006-11-27T14:34:50.783-06:00 Error sending SOAP
message to the repository. Error was SOAP FAULT
[40] => Log overflow, the log was trimmed since it is to
[41] => 2006-11-27T14:34:50.798-06:00 Sending Audit
message: <13>Nov 27 14:34:50 198.81.193.235 <?xml version="1.0"
AuditSourceID="198.81.193.235"/><EventIdentification EventActionCode="R"
EventDateTime="2006-11-27T14:34:50.783-06:00"
EventOutcomeIndicator="8"><EventID code="110106" codeSystemName="DCM"
displayName="Export"/></EventIdentification><ActiveParticipant
UserID="dhale" UserIsRequestor="true"><RoleIDCode code="110153"
displayName="Source"/></ActiveParticipant><ActiveParticipant
UserIsRequestor="false"><RoleIDCode code="110154" codeSystemName="DCM"
Media"/></ActiveParticipant><ParticipantObjectIdentification
ParticipantObjectID="1.3.6.4.1.4.1.2835.2.7777"
ParticipantObjectTypeCode="2"
ParticipantObjectTypeCodeRole="3"><ParticipantObjectIDTypeCode
code="110180" codeSystemName="DCM" displayName="Study Instance
UID"/></ParticipantObjectIdentification><ParticipantObjectIdentification
ParticipantObjectID=" JM19400814^^^&amp;1.3.6.1.4.1.21367.2005.1.1&amp;ISO "
ParticipantObjectTypeCode="1"
ParticipantObjectTypeCodeRole="1"><ParticipantObjectIDTypeCode
code="2"/></ParticipantObjectIdentification></AuditMessage >
[42] => Log overflow, the log was trimmed since it is to
Here's my parameters array, containing the sessionContext,
base64EncodedDocument and metadata. My first suspicion was that I was
sending a blank document, but after checking the parameters I'm pretty
sure that's not the case.
Array
[sessionContext] => sessioncontext Object
[user] => dhale
[sessionID] => 32b40e8ab5965b57aa9514ec053541c3
[rhioName] => ibmod235-all
[userApplicationName] => openEMR
[userFacilityName] => Test Land Medical Clinic
[returnLogLevel] => DEBUG
[useSecuredConnectionWhenAvaliable] =>
[base64EncodedDocument] => (skipped for length, but it's there)
[metadata] => documentsubmissionmetadatatype Object
[documentEntryClassCode] => codedmetadatatype Object
[codeName] => Summarization of episode
[displayName] => Connect-a-thon classCodes
[schemeName] => Summarization of episode
[documentEntryConfidentialityCodeCode] => codedmetadatatype
Object
[codeName] => N
[displayName] => Connect-a-thon confidentialityCodes
[schemeName] => Normal
[documentEntryFormatCode] => codedmetadatatype Object
[codeName] => ScanPDF/IHE 1.x
[displayName] => Connect-a-thon formatCodes
[schemeName] => ScanPDF/IHE 1.x
[documentEntryHealthcareFacilityCode] => codedmetadatatype
Object
[codeName] => Outpatient
healthcareFacilityTypeCodes
[schemeName] => Outpatient
[documentEntryParentDocumentId] =>
[documentEntryPracticeSettingCode] => codedmetadatatype Object
[codeName] => General Medicine
[displayName] => Connect-a-thon practiceSettingCodes
[schemeName] => General Medicine
[documentEntryTypeCode] => codedmetadatatype Object
[codeName] => 34133-9
[displayName] => LOINC
[schemeName] => Summarization of Episode Note
[documentType] => CDA
[patientId] => patientidtype Object
[idNumber] => JM19400814
[assigningAuthorityType] => assigningauthoritytype
Object
[namespaceId] => HIMSS2005
[universalId] => 1.3.6.1.4.1.21367.2005.1.1
[universalIdType] => ISO
[universalIdTypeCode] =>
[useDefaultAssigningAuthority] =>
[submissionSetContentTypeCode] => codedmetadatatype Object
[displayName] => Connect-a-thon contentTypeCodes
[submissionSetSourceId] => 1.2.3.4.5
Any ideas on why it's failing?
-Dan
Re: error when uploading documents [message #24787 is a reply to message #24751] Mon, 27 November 2006 21:49 Go to previous messageGo to next message
Thanks, I'll look at it.
Please submit the bug to the bugzilla
(http://wiki.eclipse.org/index.php/Submit_Bugs_to_OHF). Issues I have
there will be address much faster. It is my prime todo list, in addition
the one who submitted a bug and myself are getting a notice about a new
bug instantly where the newsgroup might be slower.
--eishay
Dan Hale wrote:
> Eishay Smith wrote:
>> Hi Dan,
>> method.
>> pass the Connectathon tests and NHIN. The method gives too much
>> control over the metadata to the bridge. We also didn't test our PHP
>> samples that works with it yet since the API change.
>> method passed the NIST testes with the NIST server.
>> --eishay
> [29] => 2006-11-27T14:33:49.531-06:00 Sending Audit message:
> [33] => 2006-11-27T14:33:49.547-06:00 Submitting Provide and
> [41] => 2006-11-27T14:34:50.798-06:00 Sending Audit message:
> Array
> [user] => dhale
> Object
> [codeName] => N
> Object
> Object
> -Dan
Re: error when uploading documents [message #24822 is a reply to message #24751] Mon, 27 November 2006 21:57 Go to previous message
Please see my last comment to bug #165582
Tim had reported the bug today too. Please use the NIST servers for
Connectathon tests, if you have to use the Dallas servers (2006 version
of XDS), we will supply 2006 computability patched server for NHIN
participants.
--eishay
Dan Hale wrote:
> Eishay Smith wrote:
>> Hi Dan,
>> method.
>> --eishay
> Array
> [user] => dhale
> Object
> [codeName] => N
> Object
> Object
> -Dan
Re: error when uploading documents [message #575515 is a reply to message #24487] Sat, 25 November 2006 02:54 Go to previous message
--eishay
> can I find out?
> Thanks!
> -Dan
Re: error when uploading documents [message #575644 is a reply to message #24528] Sun, 26 November 2006 17:21 Go to previous message
> --eishay
>> can I find out?
>> Thanks!
>> -Dan
little better.
[0]=>
[1]=>
array(2) {
["user"]=>
string(5) "dhale"
["sessionID"]=>
["rhioName"]=>
string(7) "openEMR"
string(5) "DEBUG"
bool(false)
["doc"]=>
NULL
["documentSize"]=>
int(230091)
["documentTitle"]=>
["effectiveTime"]=>
NULL
["encodingType"]=>
string(3) "B64"
["formatCode"]=>
NULL
["mimeType"]=>
["patientInfo"]=>
["idNumber"]=>
["namespaceId"]=>
["universalId"]=>
string(3) "ISO"
string(0) ""
NULL
["patientName"]=>
["familyName"]=>
string(6) "Murphy"
["givenName"]=>
string(5) "Joyce"
["otherName"]=>
string(5) "Marie"
["suffix"]=>
string(0) ""
["prefix"]=>
string(0) ""
string(0) ""
["patientSex"]=>
string(0) ""
["streetAddress"]=>
string(0) ""
["city"]=>
string(2) "WI"
string(5) "54603"
["country"]=>
string(0) ""
string(0) ""
NULL
NULL
["uniqueId"]=>
NULL
["uuid"]=>
NULL
Re: error when uploading documents [message #575678 is a reply to message #24672] Sun, 26 November 2006 20:53 Go to previous message
Hi Dan,
method.
--eishay
Re: error when uploading documents [message #575698 is a reply to message #24712] Mon, 27 November 2006 16:04 Go to previous message
Eishay Smith wrote:
> Hi Dan,
> method.
> --eishay
Array
[user] => dhale
Object
[codeName] => N
Object
Object
-Dan
Re: error when uploading documents [message #575732 is a reply to message #24751] Mon, 27 November 2006 21:49 Go to previous message
--eishay
Dan Hale wrote:
> Eishay Smith wrote:
>> Hi Dan,
>> method.
>> --eishay
> Array
> [user] => dhale
> Object
> [codeName] => N
> Object
> Object
> -Dan
Re: error when uploading documents [message #575787 is a reply to message #24751] Mon, 27 November 2006 21:57 Go to previous message
participants.
--eishay
Dan Hale wrote:
> Eishay Smith wrote:
>> Hi Dan,
>> method.
>> --eishay
> Array
> [user] => dhale
> Object
> [codeName] => N
> Object
> Object
> -Dan
Previous Topic:more metadata exposed when doing a document query
Next Topic:Security?
Current Time: Sat Nov 08 12:23:35 EST 2025
Powered by FUDForum. Page generated in 0.06043 seconds
