| Problemes with plugin.xml properties [message #248844] |
Wed, 13 February 2008 10:30  |
I am having a hard time undertanding what seems to be a basic concept in
plugin.xml files ...
Some attributes are of the form xxx:yyy and I do not know how it works.
For instance, when using the progress view, one must use the following
syntax :
<view
name="Progress View"
icon="icons/progress.png"
category="org.eclipse.ui"
class="org.eclipse.ui.ExtensionFactory:progressView"
id="org.eclipse.ui.views.ProgressView">
</view>
I also saw an action with the following class :
class=" org.eclipse.ui.internal.actions.ModifyWorkingSetDelegate:fal se "
or here, more complicated, in a workingSet :
elementAdapterClass=" org.eclipse.ui.BasicWorkingSetElementAdapter:org.eclipse.cor e.resources.IResource;adapt=true "
Is there somewhere on eclipse's site an explanation on how this works.
For instance, if I wanted to define my own ExtensionFactory ?
Or what is the consequence for the action class to have the ":false" ?
Is this a general common behavior ?
Any tip would be useful,
Thx in advancce.
Jean
FUDForum. Page generated in 0.08999 seconds
