Home » Language IDEs » Java Development Tools (JDT) » Eclipse frequently crashing with out of memory errors
Eclipse frequently crashing with out of memory errors [message #248576] Wed, 10 October 2007 13:44 Go to next message
I am having the problem of Eclipse 3.3.0 crashing two or three times an
hour due to an out of memory error. I am running on a Windows XP machine
with 2GB of memory and when this error occurs the Windows Task Manager
shows plenty of memory available and the Eclipse process taking up about
400MB of memory.
I am using the below in my eclipse.ini file:
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
384M
-vmargs
-Xms256m
-Xmx786m
I am using the following plugins:
Jetty Launcher
Subclipse
Maven2
Checkstyle
Below is a typical entry in the .metadata/.log file:
!ENTRY org.eclipse.core.jobs 4 2 2007-10-10 10:50:14.443
!MESSAGE An internal error occurred during: "Processing Dirty Regions".
!STACK 0
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.wst.validation.internal.ValidationRegistryReader .initializeValidator(ValidationRegistryReader.java:1376)
org.eclipse.wst.validation.internal.ValidationRegistryReader .readExtension(ValidationRegistryReader.java:1489)
Below is the first section from the Configuration Details page:
*** Date: Wednesday, October 10, 2007 10:56:03 AM MT
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=I20070625-1500
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\home\tools\eclipse\\plugins\org.eclipse.platform_3.3.1.M2 0070725\splash.bmp
-launcher
C:\home\tools\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\home\tools\eclipse\plugins\org.eclipse.equinox.launcher.w in32.win32.x86_1.0.1.R33x_v20070828\eclipse_1020.dll
-startup
C:\home\tools\eclipse\plugins\org.eclipse.equinox.launcher_1 .0.1.R33x_v20070828.jar
-vm
C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1192035318396
eclipse.vm=C:\Program Files\Java\jre1.6.0_02\bin\client\jvm.dll
eclipse.vmargs=-Xms256m
-Xmx786m
-Djava.class.path=C:\home\tools\eclipse\plugins\org.eclipse. equinox.launcher_1.0.1.R33x_v20070828.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\home\tools\eclipse\plugins\org.eclipse.eq uinox.launcher_1.0.1.R33x_v20070828.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_02\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_02\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_02
java.io.tmpdir=C:\TEMP\
java.library.path=C:\home\tools\eclipse;.;C:\WINDOWS\Sun\Jav a\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program
Files\Java\jre1.6.0_02\bin\client;C:\Program
Files\Java\jre1.6.0_02\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\System32\Wbem;C:\PROGRA~1\CA\SHARED~1\SCANEN~1;C:\P ROGRA~1\CA\ETRUST~1;C:\Program
Files\Vantive32;C:\Program Files\QuickTime\QTSystem\;C:\Program
Files\ZipGenius
6\;C:\home\tools\mule-1.3.3\bin;C:\home\tools\maven-2.0.7\bi n;C:\home\tools\svn-win32-1.4.5\bin
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_02-b06
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_02
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_02-b06
Any suggestions as to what I can do to stop this from happening will be
very much appreciated, thanks in advance.
--James
Re: Eclipse frequently crashing with out of memory errors [message #248593 is a reply to message #248576] Wed, 10 October 2007 14:45 Go to previous messageGo to next message
> machine with 2GB of memory and when this error occurs the Windows Task
> Manager shows plenty of memory available and the Eclipse process taking
> up about 400MB of memory.
> -showsplash
> 384M
> -vmargs
> -Xms256m
> -Xmx786m
I don't intend to be rude, but did you even try looking through the
message archives, Google, or Bugzilla for information about this? It is
a FAQ.
Although the eclipse.ini above looks basically correct, there are other
factors that can contribute to PermGen problems. Please look at previous
threads and Bugzilla entries for advice on narrowing the problem.
Eric
Re: Eclipse frequently crashing with out of memory errors [message #248608 is a reply to message #248593] Wed, 10 October 2007 15:44 Go to previous messageGo to next message
> a FAQ.
I did consult the FAQ and I took the steps suggested there, i.e increasing
the PermGen space via the VM args and the MaxPermSize via the --launcher
option
( http://wiki.eclipse.org/FAQ_How_do_I_increase_the_permgen_si ze_available_to_Eclipse%3F)
-- however this has brought me no joy.
Most of the articles found using Google make the same suggestions.
The only thing I have yet to try is to use a non-Sun JVM, but I'm hesitant
to go that route since other folks on my development team are running
Eclipse using a Sun JVM on exactly the same laptop configuration that I
have and they are not seeing this error.
My next step is to remove Java 1.6 to see that helps, as everyone on my
team is using Java 1.5 and they're not having these troubles.
--James
Re: Eclipse frequently crashing with out of memory errors [message #248621 is a reply to message #248576] Wed, 10 October 2007 16:48 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"James Adams" <monocongo@gmail.com> wrote in message
news:dbe86e58ca1ecf39b8e416ead29370c7$1@www.eclipse.org...
>400MB of memory.
> -showsplash
> 384M
> -vmargs
> -Xms256m
> -Xmx786m
This is an Eclipse bug; if you search Bugzilla for --launcher.XXMaxPermSize
you'll find it. The workaround appears to be to specify -XXMaxPerSize in
the vmargs, rather than to the launcher.
Re: Eclipse frequently crashing with out of memory errors [message #248811 is a reply to message #248621] Tue, 16 October 2007 12:54 Go to previous messageGo to next message
>>400MB of memory.
>> -showsplash
>> 384M
>> -vmargs
>> -Xms256m
>> -Xmx786m
Thanks Walter. I've done two things which seem to have gotten me past my
out of memory problem: 1) I uninstalled Java 1.6 and went back to using
the latest Java 1.5, and 2) I added a MaxPermSize VM argument into my
eclipse.ini file, which is shown below.
-showsplash
-vmargs
-Xms40m
-Xmx786m
-XX:MaxPermSize=160m
One thing which took a little figuring out was the correct way to specify
the MaxPermSize argument -- I'm not sure why but it's different from the
other memory arguments in that you need a colon and equals.
--James
Re: Eclipse frequently crashing with out of memory errors [message #248816 is a reply to message #248811] Tue, 16 October 2007 13:52 Go to previous message
James,
I think because it's an extended option not a standard option that all
JVMs must accept, though that doesn't explain the "=".
>>> an hour due to an out of memory error. I am running on a Windows XP
>>> Task Manager shows plenty of memory available and the Eclipse
>>> process taking up about 400MB of memory.
>>> -showsplash
>>> 384M
>>> -vmargs
>>> -Xms256m
>>> -Xmx786m
>> --launcher.XXMaxPermSize you'll find it. The workaround appears to
>> be to specify -XXMaxPerSize in the vmargs, rather than to the launcher.
> my out of memory problem: 1) I uninstalled Java 1.6 and went back to
> using the latest Java 1.5, and 2) I added a MaxPermSize VM argument
> into my eclipse.ini file, which is shown below.
> -showsplash
> -vmargs
> -Xms40m
> -Xmx786m
> specify the MaxPermSize argument -- I'm not sure why but it's
> different from the other memory arguments in that you need a colon and
> equals.
> --James
Previous Topic:Covariant return types with multiple interfaces
Next Topic:Log4J
Current Time: Mon Jul 21 21:25:40 EDT 2025
Powered by FUDForum. Page generated in 0.29926 seconds
