Home » Newcomers » Newcomers » org.eclipse.ui.examples.javaeditor sample
org.eclipse.ui.examples.javaeditor sample [message #248486] Sun, 10 February 2008 09:07 Go to next message
I am not able to get the content assist or syntax coloring to work as
documented in the "org.eclipse.ui.examples.javaeditor" example.
I am following the instructions that are documented here -
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/samples/org.eclipse.ui.examples.javaeditor/ doc-html/ui_javaeditor_ex.html
Here are the steps I followed:
1) Launched Eclipse 3.3. Clicked on Help | Welcome | Samples | Jave editor.
Followed the prompts to import the "org.eclipse.ui.examples.javaeditor"
plugin into my workspace.
2) Clicked on "run the sample" link in the cheat sheet to launch the
application.
3) Created a new project - File | New Project | Simple | Project.
4) Created a new file - Right click | New | File | "test.jav" under the
project. The java editor opens automatically.
5) When I type in java code, the content assist and syntax coloring does not
work at all.
Am I missing some steps or created the project and file incorrectly?
I have tried this Eclipse 3.1 and Eclipse 3.2 as well, with no success.
Before I spend time debugging, it would help to know if this example works
at all.
-Arvind
Re: org.eclipse.ui.examples.javaeditor sample [message #248547 is a reply to message #248486] Mon, 11 February 2008 09:43 Go to previous message
Arvind Parasuram wrote:
>Hi,
>application.
>work at all.
It works for me. Note that the code itself has the same color. Only
comments get different color.
Dani
>at all.
>Thanks,
>-Arvind
Previous Topic:Toggle cvs repository
Next Topic:debug a site
Current Time: Wed Jun 25 16:41:14 EDT 2025
Powered by FUDForum. Page generated in 0.11337 seconds
