Home » Archived » BIRT » birt runtime 2.2.0
birt runtime 2.2.0 [message #248480] Tue, 17 July 2007 14:41 Go to next message
Originally posted by: tom.oc.com
When I deploy the birt runtime 2.2.0 under the tomcat version 5.5.20 or
tomcat version 6.0.13 and attempt to run the WebSample viewer
test.rptdesign report I get a jvm crash in tomcat when trying to run the
PrintUtility class in the birt runtime. Does anyone know of any special
requirements to get this birt 2.2.0 running under tomcat 5 or tomcat 6.
Re: birt runtime 2.2.0 [message #248485 is a reply to message #248480] Tue, 17 July 2007 15:07 Go to previous messageGo to next message
Tom,
I am running 5.5 with Birt 2.2. I have no issue when hitting print
control in the nav bar. I am using Java 1.5. You should not have to
set anything special for this environment.
Jason
> the PrintUtility class in the birt runtime. Does anyone know of any
> special requirements to get this birt 2.2.0 running under tomcat 5 or
> tomcat 6.
Re: birt runtime 2.2.0 [message #248506 is a reply to message #248485] Tue, 17 July 2007 16:16 Go to previous messageGo to next message
I am not actually trying to print anything the birt runtime just goes and
trys to run the PrintUtility class for no apparent reason when running the
WebViewer sample report and then crashes the jvm. I am also running java
1.5. The way I am deploying the runtime is by just placing the birt.war file
in the tomcat webapps directory and then trying to run it via a browser thru
tomcat and it crashes the jvm when trying to get some attributes for my
windows default printer. Do I need to do something extra besides just
placing the "birt.war" in the tomcat webapps directory?
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:f7j3um$973$1@build.eclipse.org...
> Tom,
> Jason
> > tomcat 6.
Re: birt runtime 2.2.0 [message #248515 is a reply to message #248506] Tue, 17 July 2007 19:50 Go to previous messageGo to next message
Tom,
You should not have to do anything else.
Can you log a bugzilla entry for this?
Also try copying the WebViewerExample directory to the webapps directory.
You have the same setup as me. What OS are you running?
Jason
>> Tom,
>> Jason
>>> tomcat 6.
Re: birt runtime 2.2.0 [message #248704 is a reply to message #248515] Wed, 18 July 2007 11:08 Go to previous messageGo to next message
When I copy the WebViewerExample to my webapps it blows the jvm just like
the birt.war deployment does and I have also tried under tomcat 6 and same
result. I must be missing something very basic here.
news:f7jkh8$l61$1@build.eclipse.org...
> Tom,
> Jason
and
the
file
thru
> >> Tom,
> >> Jason
or
> >>> tomcat 6.
Re: birt runtime 2.2.0 [message #248733 is a reply to message #248704] Wed, 18 July 2007 12:04 Go to previous messageGo to next message
Tom,
Does it blow up when you select the print icon or anytime you run a report?
Jason
>> Tom,
>> Jason
> and
> the
> file
> thru
>>>> Tom,
>>>> Jason
> or
>>>>> tomcat 6.
Re: birt runtime 2.2.0 [message #248744 is a reply to message #248733] Wed, 18 July 2007 15:36 Go to previous messageGo to next message
It blows up anytime trying to run the report via the browser thru tomcat any
version
news:f7ldio$g7v$1@build.eclipse.org...
> Tom,
report?
> Jason
like
same
> >> Tom,
directory.
> >> Jason
> > and
> > the
java
birt.war
> > file
browser
> > thru
my
> >>>> Tom,
> >>>> Jason
> > or
run
or
> >>>>> tomcat 6.
Re: birt runtime 2.2.0 [message #248774 is a reply to message #248744] Wed, 18 July 2007 19:21 Go to previous message
Tom,
I am not certain what is happening here. Can you log a bugzilla entry.
Jason
> version
>> Tom,
> report?
>> Jason
> like
> same
>>>> Tom,
> directory.
>>>> Jason
>>> and
>>> the
> java
> birt.war
>>> file
> browser
>>> thru
> my
>>>>>> Tom,
>>>>>> Jason
>>> or
> run
> or
>>>>>>> tomcat 6.
Previous Topic:Nightly build 20070717 download fails
Next Topic:crosstab - summary field as percent
Current Time: Sun Nov 09 14:19:24 EST 2025
Powered by FUDForum. Page generated in 0.03678 seconds
