| Howto actually use the plugin? [message #24434] |
Wed, 06 August 2003 08:07  |
Originally posted by: tcn.spamgourmet.com
Hi!
I created a new AspectJ project and imported the telecom sample from the
distribution.
The editor complains about the keyword "aspect".
I switch to the AspectJ perspective but the Visualizer as well as the
Visualizer Menu views are plain empty.
So, well, how do I actually use the plugin at all? :-)
Timo
| Re: Howto actually use the plugin? [message #24475 is a reply to message #24434] |
Fri, 08 August 2003 10:42   |
Hi Timo,
First of all, to get rid of the red underlining of "aspect" and other
AspectJ keywords, you need to follow the post-installation configuration
instructions. These can be found by following the first link on the AJDT
Welcome page, or under Help->AJDT Plugin Help->AJDT->Readme (scroll down
past the release changes). In the next release, you will be automatically
prompted to perform these steps, but for now, they are manual.
Secondly, you do not need to be in the "Aspect Visualization" perspective
to work with the AJDT plugin. You can program your aspects from the Java
perspective as you would any other code.
The "Aspect Visualization" perspective is a tool that allows you to see
the places in your Java code that are affected by your pointcuts. In
order for this to work, you need to build the project first. After a
build, you should be able to see some vertical bars (representing your
classes) in the Aspect Visualizer window. Note that the Visualizer
represents the currently selected project, so you must also select the
telecom project before anything will appear. There is more help on the
visualizer (and other parts of AJDT) in the FAQ: Help->AJDT Plugin
Help->AJDT->FAQ.
Hope this helps,
~Julie
AJDT Devlopment
Timo Nentwig wrote:
> Hi!
> distribution.
> Timo
| Re: Howto actually use the plugin? [message #24939 is a reply to message #24515] |
Tue, 19 August 2003 04:33   |
Originally posted by: clemas.uk.ibm.com
Hi Timo,
Timo Nentwig wrote:
> Well, I'm not very happy with this. I don't want to disable and ignore
> everything I want eclipse to know the aspect keyword (and the outline to be
> updated while I type...) :-(
That is a piece of work we are looking to start soon: i.e better
integrating the aspectj language with eclipse - its a *hard* thing to do
as eclipse doesn't have suitable extension points. After all, why would
it need to have extension points where you could add keywords to Java,
Java is Java...
> Not very spectacular :)
> Thanks for helping (hmm, seems I'm about the only one on this newsgroup....)
We have trouble keeping track of the mailing list and the newsgroup. I
believe you are likely to get faster responses sending email to the ajdt
list - as then all the AJDT developers see it instantly, rather than when
we remember to check the group.
cheers,
Andy.
Andy Clement
AJDT Development.
| Re: Howto actually use the plugin? [message #25775 is a reply to message #25565] |
Fri, 05 September 2003 12:26  |
Timo Nentwig wrote:
>> Java is Java...
> Well, "assert" also is a fairly new keyword. And 1.5's generics require a
> new parser...
And enum is a new 1.5 keyword ;-)
uggc://avgjvg.qr
| Re: Howto actually use the plugin? [message #569722 is a reply to message #24434] |
Hi Timo,
Help->AJDT->FAQ.
Hope this helps,
~Julie
AJDT Devlopment
Timo Nentwig wrote:
> Hi!
> distribution.
> Timo
| Re: Howto actually use the plugin? [message #569746 is a reply to message #24475] |
Sat, 09 August 2003 07:44  |
Timo
| Re: Howto actually use the plugin? [message #570128 is a reply to message #24515] |
Hi Timo,
Java is Java...
cheers,
Andy.
Andy Clement
AJDT Development.
| Re: Howto actually use the plugin? [message #570988 is a reply to message #24939] |
Thu, 04 September 2003 11:27  |
> Java is Java...
new parser...
The newsgroup should be a mirror of the mailing lists et vice versa,
shouldn't it ;-)
uggc://avgjvg.qr
| Re: Howto actually use the plugin? [message #571055 is a reply to message #25565] |
Timo Nentwig wrote:
>> Java is Java...
> new parser...
uggc://avgjvg.qr
FUDForum. Page generated in 0.05765 seconds
