Home » Newcomers » Newcomers » configure printer
configure printer [message #248359] Fri, 08 February 2008 05:47 Go to next message
Originally posted by: roche.iram.fr
Eclipse : 3.3.1.1
In the File menu the "Print" action is not activated. And I didn't found
how to activate it ... it could be useful to print some documents :-) ...
Thanks for any help,
JC.
Re: configure printer [message #248369 is a reply to message #248359] Fri, 08 February 2008 06:02 Go to previous messageGo to next message
JC Roche wrote:
> Eclipse : 3.3.1.1
> found how to activate it ... it could be useful to print some
> documents :-) ...
Open it in an editor then you can print.
Dani
> JC.
Re: configure printer [message #248397 is a reply to message #248369] Fri, 08 February 2008 09:06 Go to previous messageGo to next message
>> documents :-) ...
Thanks for your answer.
If you mean an Eclipse editor, then it is the case and the print menu is
disable yet ...
Where is the configuration windows for printer is Eclipse ?
JC
Re: configure printer [message #248457 is a reply to message #248397] Sat, 09 February 2008 02:58 Go to previous messageGo to next message
>>> documents :-) ...
> is disable yet ...
This works for me if I use one of the editors from the Eclipse SDK (e.g.
Text or Java editor): the File > Print... menu becomes enabled.
Dani
> JC
Re: configure printer [message #248537 is a reply to message #248457] Mon, 11 February 2008 09:25 Go to previous messageGo to next message
Ok, so you're lucky :-)
JC.
Re: configure printer [message #248552 is a reply to message #248537] Mon, 11 February 2008 09:43 Go to previous messageGo to next message
>> (e.g. Text or Java editor): the File > Print... menu becomes enabled.
Not really. It should work for you as well if you use one of these editors.
Dani
> JC.
Re: configure printer [message #248583 is a reply to message #248397] Mon, 11 February 2008 12:01 Go to previous message
>>> documents :-) ...
> disable yet ...
There is no printer configuration in Eclipse. As Dani said, printing
"just works" if you have opened a file. What kind of file are you
looking at?
Eric
Previous Topic:Logical Comparison of XML files
Next Topic:properties file in user library?
Current Time: Sun Aug 31 23:56:29 EDT 2025
Powered by FUDForum. Page generated in 0.08026 seconds
