| Project Build hung [message #248271] |
Thu, 07 February 2008 14:01  |
Originally posted by: arichmon.csc.com
Trying to do a modest Project Build in Eclipse 3.0. After getting the
source and output folders and the build path defined, I start up Project
Build and it gets to '71%' built in a couple of minutes, but will not go
beyond '71%'. Does anyone know what can be done to fix this?
| Re: Project Build hung [message #248277 is a reply to message #248271] |
Thu, 07 February 2008 15:16  |
Originally posted by: wharley.bea.com
"arichmon" <arichmon@csc.com> wrote in message
news:402f66183f5fdc8e90924d3946285581$1@www.eclipse.org...
First, is there any reason you're obligated to use Eclipse 3.0? It's quite
old now, not really supported any more and there have been tens of thousands
of bug fixes since then, one of which might apply to you. If you are able
to upgrade to 3.3.1.1 that might solve some problems. On the other hand,
taking such a big step forward might also introduce other problems,
depending on the nature of your project.
What kind of project are you building? Is this standard Java, J2EE, C++,
PHP, .... ?
Did it use to work previously? If so, can you think of anything that might
have changed, either in the project or your environment? New third-party
plugin added, new .jar dependency, firewall settings, ...?
When you say "modest", can you be more specific?
Is this only one project, or is it true for every project you try to build?
Only one workspace, or all workspaces?
FUDForum. Page generated in 0.08850 seconds
