Home » Eclipse Projects » Eclipse Platform » Navigate -> Goto -> Referring Tests - missing in 3RC1?
Navigate -> Goto -> Referring Tests - missing in 3RC1? [message #248263] Wed, 02 June 2004 05:29 Go to next message
Originally posted by: phil.dadabeatnik.com
I'm using 3RC1 on Windows XP.
I reached for the Navigate -> Goto -> Referring Tests menu item and it's no
longer there.
Anyone know what happened?
PB
Re: Navigate -> Goto -> Referring Tests - missing in 3RC1? [message #248269 is a reply to message #248263] Wed, 02 June 2004 05:44 Go to previous messageGo to next message
We did a menu clean-up pass and I was convinced that nobody is using this
action so I've removed it - I was wrong...
--erich
"Phillipus" <phil@dadabeatnik.com> wrote in message
news:c9k668$a5d$1@eclipse.org...
no
> longer there.
> PB
Re: Navigate -> Goto -> Referring Tests - missing in 3RC1? [message #248299 is a reply to message #248269] Wed, 02 June 2004 06:20 Go to previous messageGo to next message
Hi Erich,
yes I use it all the time - it's very convenient. It would be great if you
could put it back. Does it need to be Bugzilla'd ?
PB
"Erich Gamma" <erich_gamma@ch.ibm.com> wrote in message
news:c9k72h$bag$1@eclipse.org...
> --erich
> > Hi,
> no
> > longer there.
> > PB
Re: Navigate -> Goto -> Referring Tests - missing in 3RC1? [message #248374 is a reply to message #248269] Wed, 02 June 2004 09:33 Go to previous messageGo to next message
It's been bugzilla'd:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=65299
PB
Re: Navigate -> Goto -> Referring Tests - missing in 3RC1? [message #248378 is a reply to message #248269] Wed, 02 June 2004 09:37 Go to previous message
Yes, this is very nice feature.
On this topic, it would be nice also to be able to scope actions based
on production vs test code. For example, when searching for a
callers/hierarchy/types/depedencies/etc often you just want to see the
production code -- not the tests. In Idea, the project source paths are
segregated into production and test, thus the ide knows the difference.
Its seems that in eclipse there is not first-class for this distinction.
From reading your book I see that you create a seperate project for
test code. I have been doing the same. Maybe there could be a subtype of
a java project that is specifically for tests. Or maybe some other
mechanism...
Previous Topic:Horizontal Perspective bar vanished
Next Topic:difference between 2.1.3 and 3.x version.
Current Time: Thu Aug 14 15:21:21 EDT 2025
Powered by FUDForum. Page generated in 0.05738 seconds
