Home » Eclipse Projects » Eclipse Platform » BundleActivator Problem
BundleActivator Problem [message #248245] Wed, 02 June 2004 04:15 Go to next message
Originally posted by: dirksnews.gmx.de
I ported my application to 3.0 M9 and changed my plugin class to work as
bundle activator. Anything works fine when starting a runtime workbench
from my development workbench. When I deploy my plugins to eclipse M9
itself and start my perspective I get the following log entries. Whats
wrong here?
Thanks in advance,
Dirk
!ENTRY org.eclipse.osgi Jun 02, 2004 10:13:44.840
!MESSAGE An error occured while automatically activating bundle
com.vector.easee.adminenvironment.launcher (109).
!STACK 0
org.osgi.framework.BundleException: The activator
com.vector.easee.adminenvironment.launcher.LauncherPlugin for bundle
com.vector.easee.adminenvironment.launcher is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:158)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:933)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:107)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:371)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:93)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:131)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:124)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:186)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:183)
org.eclipse.ui.internal.registry.PerspectiveDescriptor.creat eFactory(PerspectiveDescriptor.java:130)
org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Pers pective.java:585)
org.eclipse.ui.internal.Perspective.createPresentation(Persp ective.java:191)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:98)
org.eclipse.ui.internal.WorkbenchPage.createPerspective(Work benchPage.java:1116)
org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPage.java:721)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:713)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2854)
org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.java:2852)
org.eclipse.ui.internal.ChangeToPerspectiveMenu.run(ChangeTo PerspectiveMenu.java:87)
at org.eclipse.ui.actions.PerspectiveMenu.run(PerspectiveMenu.j ava:303)
org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveM enu.java:318)
org.eclipse.ui.actions.PerspectiveMenu$4.widgetSelected(Pers pectiveMenu.java:134)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2716)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2382)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1363)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1334)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:253)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:97)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:307)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:256)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/core/runtime/IStatus
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:153)
... 51 more
Root exception:
Re: BundleActivator Problem [message #248279 is a reply to message #248245] Wed, 02 June 2004 06:02 Go to previous messageGo to next message
Does your activator have a public zero-arg constructor?
"Dirk Segelhorst" <dirksnews@gmx.de> wrote in message
news:c9k1t2$4q1$1@eclipse.org...
> wrong here?
> Thanks in advance,
> Dirk
> !STACK 0
> at
> at
xtImpl.java:933)
> at
ava:421)
> at
..java:293)
> at
assLoader.java:107)
> at
oader.java:371)
> at
..java:402)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
..java:307)
> at
a:336)
> at
ndle.java:1313)
> at
> at
> at
> at
:183)
> at
> at
> at
> at
116)
> at
721)
> at
> at
java:87)
> at
> at
:134)
> at
> at
> at
java:307)
> at
> at
> at
> ... 51 more
> Root exception:
> at
> at
xtImpl.java:933)
> at
ava:421)
> at
..java:293)
> at
assLoader.java:107)
> at
oader.java:371)
> at
..java:402)
> at
> at
..java:307)
> at
a:336)
> at
ndle.java:1313)
> at
> at
> at
> at
:183)
> at
> at
> at
> at
116)
> at
721)
> at
> at
java:87)
> at
> at
:134)
> at
> at
> at
java:307)
> at
> at
Re: BundleActivator Problem [message #248289 is a reply to message #248279] Wed, 02 June 2004 06:15 Go to previous messageGo to next message
Yes, it does. Here is the code snippet:
* Constructor for LauncherPlugin.
public LauncherPlugin()
super();
plugin = this;
//open the db login dialog (SWT)
Are there any problems with that one?
Re: BundleActivator Problem [message #248309 is a reply to message #248289] Wed, 02 June 2004 06:44 Go to previous messageGo to next message
Wait a sec, that bit about opening the db login...
....the bundle is not yet properly 'initialized' when the constructor is
called. I'll bet that the 'db login' code is failing (probably because the
SWT classes are not yet available, or some other classloading problem) and
that is preventing Eclipse from creating your activator. Move all code in
the constructor to the start method instead, I'll bet that's the problem.
news:c9k8tl$dsj$1@eclipse.org...
> super();
> plugin = this;
Re: BundleActivator Problem [message #248324 is a reply to message #248309] Wed, 02 June 2004 07:18 Go to previous messageGo to next message
Hi Ted,
i moved the code. But the result is the same (same exception in log file).
The weird thing is: running my plugins via "Run->Run As->Run-time
Workbench" works properly but having them in my eclipse plugin directory
not. I cannot understand that...
New code snippets:
super();
plugin = this;
* Method start.
* @see
org.osgi.framework.BundleActivator#start(org.osgi.framework. BundleContext)
public void start(BundleContext context) throws Exception
super.start(context);
DBLoginDialog login = new DBLoginDialog(Display.getCurrent(), new
Shell(Display.getCurrent()));
login.display();
>> super();
>> plugin = this;
Re: BundleActivator Problem [message #248417 is a reply to message #248245] Wed, 02 June 2004 11:53 Go to previous message
Hi Dirk,
I realy have no experience in writing Eclipse plugins but I have 3+ years
experience in developing bundles for the OSGi platform. I have had my fair
share of NoClassDefFoundError's and here are first steps I'd take in fixing
the problem:
1) I'd make *really* sure that you have the org.eclipse.core.runtime package
mentioned in the Import-Package clause of the plugin bundle's MANIFEST.MF?
2) If you have that package mentioned I'd check if the IStatus interface
refers to classes/intefaces from packages you have forgotten to mention - if
this is the case the IStatus will not be loaded since all the clases it
depends on are not loaded and you'll still get the dreaded
NoClassDefFoundError.
3) By specification the OSGi platform provides some basic packages to all
Bundles like the "java.*", and "org.osgi.framework". The case might be that
Eclipse extends this behaveour by providing also the core Eclipse packages.
If this is the case you're not supposed to mention none of the core packages
in the MANIFEST.MF. However you still might try listing them there. Trying
won't hurt :P
Finally I'm guessing the reason why the plugin works when you launch it with
"Run->Run As->Run-time Workbench" is that Eclipse launches the plugin not as
a stand-alone OSGi Bundle in a dedicated ClassLoader but within an existing
ClassLoader that has all necessary packages already defined. This is
however a preaty wild guess and I won't be surprised if i'm wrong :)
Best of luck
Todor
> wrong here?
> Thanks in advance,
> Dirk
> !STACK 0
> at
> at
xtImpl.java:933)
> at
ava:421)
> at
..java:293)
> at
assLoader.java:107)
> at
oader.java:371)
> at
..java:402)
> at
> at
..java:307)
> at
a:336)
> at
ndle.java:1313)
> at
> at
> at
> at
:183)
> at
> at
> at
> at
116)
> at
721)
> at
> at
java:87)
> at
> at
:134)
> at
> at
> at
java:307)
> at
> at
> at
> ... 51 more
> Root exception:
> at
> at
xtImpl.java:933)
> at
ava:421)
> at
..java:293)
> at
assLoader.java:107)
> at
oader.java:371)
> at
..java:402)
> at
> at
..java:307)
> at
a:336)
> at
ndle.java:1313)
> at
> at
> at
> at
:183)
> at
> at
> at
> at
116)
> at
721)
> at
> at
java:87)
> at
> at
:134)
> at
> at
> at
java:307)
> at
> at
Previous Topic:How to configure Jikes
Next Topic:TableCursor breaks JFace CellEditors
Current Time: Sat Jul 26 09:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.04860 seconds
