Home » Eclipse Projects » GEF » Animation on editpart
Animation on editpart [message #248208] Thu, 09 April 2009 15:06 Go to next message
I have requirement to show animation on editparts. i,e i have set of
connections which has a source and traget node.
On a event i need to highlight the single node at a time till it reaches
its target point node
eq
A C1 B C2 D
where C1 and C2 are connections and A,B and D are the nodes
with the below implementationn it is all the nodes are get highlighted
together but what i need is first highlight the A,then some time interval
B and then C
private void blinkingFeature(Set<ConnectionEditPart> tracedConnEditParts)
for (ConnectionEditPart connectionEditPart : tracedConnEditParts)
final GraphicalEditPart targetEditPart =
(GraphicalEditPart)connectionEditPart.getTarget();
final GraphicalEditPart sourcEditPart =
(GraphicalEditPart)connectionEditPart.getSource();
Thread thread1 = new Thread(new AnimatePort(targetEditPart));
thread1.start();
Thread thread2 = new Thread(new AnimatePort(sourcEditPart));
thread2.start();
private class AnimatePort implements Runnable
GraphicalEditPart graphicalEditPart;
public AnimatePort(final GraphicalEditPart graphicalEditPart)
this.graphicalEditPart = graphicalEditPart;
public void run() {
for(int i = 1; i < 20;i++)
if(i % 2 == 0)
Display.getDefault().syncExec( new Runnable(){
public void run() {
setColorBorder(graphicalEditPart, ColorConstants.red);
}else
public void run() {
setColorBorder(graphicalEditPart, ColorConstants.black);
try {
Thread.sleep(300);
} catch (InterruptedException e) {
// TODO Auto-generated catch block
e.printStackTrace();
I tried the thread join but it us blocking my UI update process. Any idea
how achive this ?
Byre
Re: Animation on editpart [message #642712 is a reply to message #248208] Thu, 02 December 2010 08:26 Go to previous message
Hello all,
I want to achieve the same, any updates????
Thanks in advance for any help. Smile
[Updated on: Thu, 02 December 2010 08:31] by Moderator
Previous Topic:Customize Palette
Next Topic:Animation on Connection.
Current Time: Wed Jul 23 18:08:39 EDT 2025
Powered by FUDForum. Page generated in 0.06221 seconds
