Home » Language IDEs » Java Development Tools (JDT) » Java formatter
Java formatter [message #248133] Wed, 26 September 2007 11:00 Go to next message
Hi there,
I'm having the problem that the formatter puts our code in a format that
causes checkstyle warnings which we would like to avoid.
The problem is with the following code:
public static SOAP getSoap()
if (Soap == null) { throw new IllegalStateException("Soap==null. "
+ "InitUtils.init() was not called or failed"); }
return Soap;
If I put the closing brace of the if clause into a new line, the formatter
puts it to the now place, at the end of its body. I have taken a look on
various options in the formatter but could not find any that would prevent
this. Do you know any?
- Gergely
Re: Java formatter [message #248206 is a reply to message #248133] Thu, 27 September 2007 10:49 Go to previous messageGo to next message
Gergely Buday wrote:
> Hi there,
> that causes checkstyle warnings which we would like to avoid.
> return Soap;
> formatter puts it to the now place, at the end of its body.
If I format that code with default formatter settings (out of the box) I
get:
public static SOAP getSoap() {
if (Soap == null) {
return Soap;
So what's the problem?
Dani
> I have taken a look on various options in the formatter but could not
> find any that would prevent this. Do you know any?
> - Gergely
Re: Java formatter [message #248216 is a reply to message #248133] Thu, 27 September 2007 13:34 Go to previous message
> return Soap;
> formatter puts it to the now place, at the end of its body. I have taken
> a look on various options in the formatter but could not find any that
Did you try to change the brace setting for block to "Next line"?
Olivier
Previous Topic:Example of org.eclipse.ui.editors.templates extension point?
Next Topic:Question on Marker use (APT vs. JavaModel)
Current Time: Sun Aug 31 08:29:02 EDT 2025
Powered by FUDForum. Page generated in 0.03341 seconds
