| Drag & Drop [message #248073] |
Fri, 03 April 2009 18:25 |
I'd like to be able to drag a GraphicalEditPart to another one and have
this result in certain properties of the model of the former being copied
to the model of later. This ought to be simple as no new objects are
created and nothing is moved, but it's different from the examples I've
come across so far.
So far I have the following code that lets me drag a selected
GraphicalEditPart to other drop targets such as an existing TableViewer
(set up with tableViewer.addDropSupport()):
graphicalViewer.addDragSourceListener(new TransferDragSourceListener() {
public void dragStart(DragSourceEvent event) {
event.doit = true;
public void dragSetData(DragSourceEvent event) {
if
(LocalSelectionTransfer.getTransfer().isSupportedType(event. dataType)) {
LocalSelectionTransfer.getTransfer().setSelection(graphicalV iewer.getSelection());
public Transfer getTransfer() {
return LocalSelectionTransfer.getTransfer();
But how do I make a GraphicalEditPart a drop target? I've registered a
TransferDropTargetListener that creates a custom "UpdateRequest", but that
alone doesn't seem to do the trick...
graphicalViewer.addDropTargetListener(new
AbstractTransferDropTargetListener(graphicalViewer,
LocalSelectionTransfer.getTransfer())) {
protected Request createTargetRequest() {
return new UpdateRequest();
protected void updateTargetRequest() {
Object target = graphicalViewer.findObjectAt(getDropLocation());
((UpdateRequest) getTargetRequest()).setTarget(target);
It seems I might also have to register a custom "EditPolicy" via
GraphicalEditPart.installEditPolicy, but using what Policy key?
FUDForum. Page generated in 0.02456 seconds
