Export compiler warning/error settings? [message #247884] |
Wed, 19 September 2007 12:57  |
Is it possible to export/import the compiler warning/error settings? We'd
like for our entire team to use the same settings, and it'd be easier to
do if we could just export/import these like you can do with the code
formatting settings.
Thanks in advance for your suggestions.
--James
Re: Export compiler warning/error settings? [message #247914 is a reply to message #247909] |
Wed, 19 September 2007 18:58   |
--------------090808070401000303060900
Dave,
Yes, I should have mentioned that. What would be cool would be a way to
share the settings between projects instead of saving a copy per project...
Dave Wegener wrote:
> You can set these up on a per project basis. They are then saved in a
> .settings folder in the root of the project. Checking the .settings folder
> into your SCM along with the rest of the project files will make the
> settings available automatically if someone checks the full project out.
> When setting up new projects, you can copy the .settings folder from an
> existing project.
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:fcrmbj$s6p$1@build.eclipse.org...
>> James,
>> There is a specific request for a category for this:
>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543
>> Right now you can export all your preference and the compiler ones will
>> be among them.
>>> We'd like for our entire team to use the same settings, and it'd be
>>> easier to do if we could just export/import these like you can do with
>>> the code formatting settings.
>>> --James
<html>
<head>
<title></title>
</head>
Dave,<br>
<br>
to share the settings between projects instead of saving a copy per
project...<br>
<br>
<br>
Dave Wegener wrote:
<blockquote cite="mid:fcs2um$90p$1@build.eclipse.org" type="cite">
<pre wrap="">You can set these up on a per project basis. They are then saved in a
..settings folder in the root of the project. Checking the .settings folder
existing project.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fcrmbj$s6p$1@build.eclipse.org">news:fcrmbj$s6p$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">James,
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543">https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543</a>
be among them.
James Adams wrote:
</pre>
<pre wrap="">Is it possible to export/import the compiler warning/error settings?
--James
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090808070401000303060900--
Re: Export compiler warning/error settings? [message #247929 is a reply to message #247924] |
Thu, 20 September 2007 01:08  |
Eric,
I probably should have but I'm usually reluctant to ask for new things
because the queue is already so big...
Eric Rizzo wrote:
> Ed Merks wrote:
>> Dave,
>> project...
> You can do that with Formatter preferences; they have the notion of a
> formatting "profile" which would be a nice concept to apply to the
> errors/warnings preferences group.
> Ed, why don't you enter an enhancement request for it...
> Eric
>>> folder
>>> out.
>>> existing project.
>>>> James,
>>>> will
>>>> be among them.
>>>>> with
>>>>> --James
FUDForum. Page generated in 0.44555 seconds
