Home » Eclipse Projects » GEF » Keep palette tool selected when shift is pressed
Keep palette tool selected when shift is pressed [message #247881] Tue, 24 March 2009 12:30 Go to next message
I have used GEF to write a form editor for our language, where the
palette contains a tool for creating each kind of widget (textfield,
button, etc.). By default the selected tool becomes deselected when it
is used, i.e. when a widget is created on the form. However, I have a
feature request for the selected tool to stay selected after use if it
was selected with the Shift key pressed. Is it possible to achieve this?
I have found the unloadWhenFinished() method which controls this
behaviour and managed to make it so that tools stay selected. However,
the problem is in detecting whether shift is pressed when the tool is
selected. The SWT mouse event does not give this information. Can anyone
help?
I suppose this is an SWT question as much as a GEF question, so perhaps
I will ask on the SWT newsgroup too.
Re: Keep palette tool selected when shift is pressed [message #247928 is a reply to message #247881] Sat, 28 March 2009 23:06 Go to previous messageGo to next message
1] Subclass the appropriate Tool
2] Extend activate(), capture getCurrentInput().isShiftKeyDown() as your
own flag
3] Override unloadWhenFinished() to do the right thing
Seems like it would work? Perhaps I am missing something.
Cheers
Ben
> help?
Re: Keep palette tool selected when shift is pressed [message #248001 is a reply to message #247928] Tue, 31 March 2009 13:15 Go to previous message
> own flag
Thanks Ben,
I overlooked the getCurrentInput() method, and did it the hard way by
overriding a couple of classes so I could get to the original
MouseEvent. I shall rewrite it now to do it the easy way.
Previous Topic:Regarding org.eclipse.ui.views.properties.PropertySheet
Next Topic:Unable to drag shapes
Current Time: Wed Sep 24 13:59:32 EDT 2025
Powered by FUDForum. Page generated in 0.28810 seconds
