Home » Archived » BIRT » Multiple Dataset Parameter Bindings ?
Multiple Dataset Parameter Bindings ? [message #247860] Fri, 13 July 2007 13:27 Go to next message
Originally posted by: amanda.helstrom.columbiaultimate.com
I am working with BIRT 2.1.1. I have two data sources that I am trying
to report on. I have created a list report with a data set from one
data source and I am attempting to create a sub report from the second
data source. I need to bind the sub report dataset with multiple
parameters from the main report. The binding works with one parameter,
but the data displayed is not correct as it needs to be restricted by
the 2nd parameter. Both parameters are integers.
Does any one have any suggestions?
Thank you in advance,
Amanda
Re: Multiple Dataset Parameter Bindings ? [message #248439 is a reply to message #247860] Tue, 17 July 2007 12:27 Go to previous message
Amanda,
Is the sub report a separate report or a nested table?
Jason
Amanda wrote:
> Hello,
> Amanda
Previous Topic:ReportEngineFactory ClassCastException (BIRT 2.2)
Next Topic:Saving parameters
Current Time: Fri Jul 25 23:24:50 EDT 2025
Powered by FUDForum. Page generated in 0.05039 seconds
