Home » Archived » BIRT » About BIRT VIEWER
About BIRT VIEWER [message #247759] Fri, 13 July 2007 01:52 Go to next message
Hi, I have been using BIRT Runtime 2.1.2 with JAVA 1.4.2_04 for my web
application.
I have created a new report using a Report Parameter, and the report
simply shows the Report Parameter.
The report shows the correct value in PDF format after I open Internet
Explorer,
but it shows the same value even if I change the Report Parameter in the
address bar in the Internet Explorer like below.
("passName" is a report parameter)
(before) http://localhost/birt-viewer/frameset?__report=report\PointF orecast.rptdesign&__format=pdf&passName=3
(after) http://localhost/birt-viewer/frameset?__report=report\PointF orecast.rptdesign&__format=pdf&passName=4
It seems that Birt Viewer uses the cache of the report.
How can I solve this problem?
Thank you and sorry for my bad English.
Hiroshi
Re: About BIRT VIEWER [message #247763 is a reply to message #247759] Fri, 13 July 2007 01:59 Go to previous message
I'm sorry, but I solved this problem by myself.
I jsut used "http://localhost/birt-viewer/run?" instead of
"http://localhost/birt-viewer/frameset?".
Thank you.
Previous Topic:Need some advice on report design - Please help
Next Topic:problem to run MySQL Aggregate Functions in birt 2.1.1
Current Time: Sun Jul 27 07:20:22 EDT 2025
Powered by FUDForum. Page generated in 0.24238 seconds
