| Locale set via report parameter [message #247720] |
Thu, 12 July 2007 16:21  |
Originally posted by: fabinader.gmail.com
Hi all,
Is there a way to allow the user to set the locale of the report on the
report parameter screen? I mean, I tried and it didn't passed my first
test. The test was: to create a parameter named __locale, set it as hidden
and put the default locale as pt_BR. When I previewed the report it was
not translated, and if I put the parameter explicitely on the URL for
WebViewer it is translated. In other words, does anybody knows if this
approach works?
Fuad Abinader
| Re: Locale set via report parameter [message #247856 is a reply to message #247837] |
Fri, 13 July 2007 13:16  |
Faud,
You are correct.
Jason
Fuad Abinader wrote:
> Hi Jason,
> The point is that I do not want to set it at the URL, I want to allow
> the user to set it on the report parameter UI, together with the other
> report parameters. In order to do that, I've created a report parameter
> named __locale, and set it to pr_BR, but it didn't localized my report.
> If I put __locale excplicitelly on the URL, it works. Somehow I'm
> realizing that these special report parameters like __format and
> __report cannot be set at design time. Am I wrong?
> Fuad Abinader
FUDForum. Page generated in 0.23838 seconds
